Changed tranny oil today
San Juan Puerto Rico
Website
www.facebook.com
Finished changing the tranny oil on my 80. Used Amsoil ATF, can anyone tell me if that was a good choice of ATF?:steer:
I used valvoline full synthetic ATF. Good stuff. Easy change too with the cooling lines.:D
Ok guys blast me if I messed up,I just did mine yesterday(drain&fill).I used Peak ATF Dexron 3/Mercon.This is what my local Toyota parts guy sold me.The FSM says to use Dexron 2,what is the differance here.I thought I was using the right stuff,I have not even driven the truck yet.
Thanks,John
Hey jsuthey. I think that our trucks are rated for the highest level of quality at the time. Or something like that. So they require at least Dexron 2, or the equivalent or higher. So I'm sure the Dexron 3 will be fine. However, if I am wrong, someone will correct me before long. I think I'm right though. : ).
Thanks,John
Here is a good thread (with the exception of one rather annoying poster :hillbilly:) discussing ATF fluid and older vs. newer recommendations.
https://forum.ih8mud.com/80-series-...er-case-differential-engine-transmission.html
I have no experience with the Peak ATF stuff you used (I use Valvoline MaxLife something or other) but I'm sure you'll be fine. If you are concerned then just do a drain and fill at every oil change with something different. I can't remember who put it together but there was actually a spreadsheet created that would show you how many drain and fill cycles it would take to get to whatever % of new fluid you were wanting to attain. IIRC it was around 19 or 20 drain and fill cycles to achieve 100%. Easier IMO to just do a home "flush" but if your fluid looks good (bright red color) and smells good (not burnt) you'd be wasting $$.
Really, unless you are doing a lot of offroading, towing, etc. where the tranny is getting a serious workout on a regular basis I wouldn't worry about it...Run what you put in there and just do a drain and fill every oil change or so depending on how many miles you put on every year and depending upon what your oil change interval is :cheers:
I have a 1996 L/C. What are the steps to changing my transmission fluid? I just want to drain and then top off. What are the steps to accomplishing this? Thanks!
Lots of recent threads on this subject (one or two by me). Do a search and read a few of the threads. By draining and topping off you are only changing about 3 quarts out of a total capacity of 12.
There is a drain plug on the pan for this purpose.
you can get about 4 quarts out with the drain plug removed.....add about 3.5 and go from there when refilling....I have seen a post where some have left the drain plug out for long periods of time and have removed more.......I usually change 4 quarts every other oil change....atf looks clean...I use mobil 1atf....make sure you have a good funnel....
So, lets say that we want to get the fluid transfused - all of it done - by the machines that hook up to the circulation lines and cycle all o of the old fluid out. Anyone had any experience with that with their 80? I've done it on explorers and tahoes, but not the cruiser - and it is time.
Funny thing, the local service joint I use, who is very good, says that these Cruisers sometimes take special training or tools compared to "regular cars" - recently he could not hook up a scanner during a CEL incident. Don't think he was BSing me, he said he did not have someone qualified at the time to work on the cruiser.
https://forum.ih8mud.com/80-series-tech/205645-transmission-service.html
Read post 10 in particular.
You can go to the B&G website and find shops with transmission fluid exchange machines in your area. Doesn't mean they know how to use them on a Landcruiser so do your homework.
The tranny only holds like 6.2 qts.(I don't have my FSM handy rt. now) I drained out 6qts.& then added 6- just to be careful not to overfill(I measured out the old fluid).I have not gone through the procedure to check it yet,my driveway is not level at all.
The Haynes manual was saying to drop the pan&clean,replace a filter in there.Does anyone do this to their FZJ80's? I don't recall reading about this in the FSM.I will look again& check out some of these other threads.
~ 12 Quarts my friend. Per the FAQ and I've verified via the FSM:
Transmission
11.0 liters (11.6 US qts, 9.7 lmp. qts)
FYI, If you're going to use a B&G machine to exchange all the fluid, they will need 16 quarts.
That's odd cause my 1993 model year manual says:
Fluid capacity (drain and refill), L (qt., lmp. qt.)
Up to 6.0 (6.5, 5.3)
That is all you will get out through the drain plug.
Find the thread that describes the transmission fluid exchange. It is pretty easy. Check your level first, then set it up to drain your outflow into a gallon container, when it is full, put four qts back in, repeat several times.
Just for clearification for some: A drain and fill drains the fluid in the pan not the system. Think of it like your radiator. It holds some of your coolant. There is more in your block, heater cores and hoses. You can drain and fill your system through your radiator petcock and be half done with it.
When I switched over to syn fluid we ran a full 4 gallons through it to make sure we got all the old out. The fluid started clearing up at @ 3 gallons.
:cheers:
Of course, that's why i said (drain and refill). I didn't say fluid exchange ;)
