Center Diff lock
Spike, Tools,
Clearly we have some differences here.
Tools,
The planetary gears I referred to, two of them, are apparently two of the four gears you refer to. The other two gears, a little larger it looks like, are what I call sun gears. So, for me, two planetary gears and two sun gears, for you, four. I believe what I call sun gears are sometimes referred to as spider gears...
Kalawang
Maybe a couple of pix from the FSM will help?
My main use of the CDL switch is the lazy locker user syndrome.:D A lot of our trails have an obstacle, then relatively easy going, obstacle, repeat. I setup the lockers for the first obstacle, as soon as I clear it, hit the CDL switch unlocking everything, at the next obstacle just hit the CDL and everything locks, repeat.:D
:idea: I never thought of doing that. What condition does that create with the lockers? Is it back into awd mode? Does it matter that the rear and or front lockers are still engaged?
I do not accept that my diffs are locked simply because I've lit up the indicator by pushing the button. I do accept that the actuator is trying to engage a lock on the diff, but it isn't always immediatly successful regardless of the light.
If the light is flashing power is sent to the actuator, but the diff is unlocked, when the light is on (no flashing) it's locked. If your's has failed and the light is solid when unlocked, please take it apart and document this new failure mode for us.
You are correct that with the Center Diff locked, power is equally applied to all wheels, at least for as long as the Diff Lock can hold.
When the CDL is locked the driveshafts turn at the same speed, locked together. Unless you lock the axle diff(s) the axle diffs can still slip, so 2 wheel drive, when the axle diffs are also locked, you have true locked 4 wheel drive. They will remain that way until turned off, I don't understand the "can hold" thing, it is a gear, spline coupling, there is NO slip.
Spike, Tools,
Spike,
I do not accept that my diffs are locked simply because I've lit up the indicator by pushing the button. I do accept that the actuator is trying to engage a lock on the diff, but it isn't always immediatly successful regardless of the light. You are correct that there has to ba a degree of difference in the turning of the wheels for the diff lock to engage but that is not always an immediate effect with the pressing of the button and the light coming on. We shall have to agree to disagree here.
K
It works this way. The switch for 'locked' is activated by full locked travel of the dog clutch arm. Anything less that full locked travel, the light is off. You can in theory still have the dog clutch partially engaged with the light off, but I did a lot of playing (predicting) with this at Steamboat Ice track, and found the light follows actual activation and deactivation, regardless of actual switch position.
My example of the one side slippage was wrong and not applicable to the engaged CDL. You are correct that with the Center Diff locked, power is equally applied to all wheels, at least for as long as the Diff Lock can hold. In my example I would probably lose some speed and maybe a little handling, but the Toy would still climb. In AWD it would not.
There's a thread on this forum that explains this better. Speed is equal when the diff is locked, power (torque) is equal only when in awd mode. Supported torque can be 100% at either axle with CDL on. On the open (awd mode) supported torque is always equal at 50/50. In awd mode neither axle can support more thatn 50% of the power, nor can the combined torque of both axles exceed twice that of the axle with the higher supported torque.
HTH
Scott J
Gentlemen,
I wish to thank you all for your inputs.
Considering the nature of your responses, I am now convinced something is wrong with my CDL setup and I have to give real consideration to upgrading to lockers or, if the repair is possible and cheap enough, repairing my CDL setup.
Just to clarify, I do get a steady light when I depress the CDL button but the handling and performance of my 80 remains normal most times. I've been trying to activate it regularly when leaving home just to get it working more reliably but regardless of that sound and the light, my tires don't chirp on pavement when turning except for those rare times. I don't do this long because I'm scared silly of the thing activating at any speed, so I only do this CDL thing near home at very low speed or when out of the city on a roomy dirt road.
I think I need the CDL or lockers more than I need my winch, given that I go places alone and there are very few or no trees most of the time.
I'm going to have to put some money aside for this.
Thank you all for the advice. It's the great thing about this board.
Kalawang
Wow. Well, good luck getting that fixed then.
Just for the record, it's not all that obvious when the CDL engages. The handling doesn't change radically, if at all when driving straight, and very little when turning. I can't even tell the thing is on unless I take a sharp turn, and that's on pavement. Maybe mine's defective too. Seems to work on obstacles, thank goodness.
I can't help but think that you know your CDL is fine, and you're messing with my head. Not sure why, but heck, I like a good joke as much as the next guy. I'm anxious to hear the punch line though.
-Spike
In Prescott I do a lot of really icy (dicey) driving. Altitude is at the level where most roads thaw and freeze a lot. The 80 has really uncanny traction without lockers. I have the CDL, but haven't done the pin 7 mod. I'm busy or I am a wimp or whatever. I have done a lot of slippery roads. I have rarely used the lockers. On ice the lockers will hurt as often as they will help.
In dry conditions I use the lockers a lot, but in ice I prefer to keep it all open.
Before I bought real tires (315 Nittos) I was running stock rubber on a 3" lift. Dryrotted hard Michelins even! With highway tread! I drove up to 9,000 feet altitude in deep snow and ice in the winter. I never even slipped a wheel. I had perfect traction at all times. I was impressed! I drove for 9 miles on sheet ice without any problems. The 80 is unbelieveable. The Gods are in the drivetrain! There is something unnatural in the way that an 80 grips the surface. It is the most incredible truck.
In my old Montero, I would have wanted chains on all four wheels. In the cruiser, I didn't even care. The traction was unnatural. It handled on ice like it was on dry pavement.
In short, let the machine do its job. It is really good at it. It is the best tool for the work at hand. Use the lockers as needed, but do not over use them. Use the gas pedal gently and play it well. When all else fails use the lockers. That is what they are there for.
The lockers can damage the truck if they are not used the right way. Use them with care. Toyota is the only manufacturer that has had the balls to put lockers in as factory. Lockers can hurt your truck if they are not used correctly. They tend to break axles and birfield joints.
I have lockers, but I use them only as a last resort.
Kalawang,
Let's put this to rest: It's incredibly simple to determine whether or not your center diff. is in fact locked (none of this "well it feels like sometimes maybe it is/isn't..."):
Raise one wheel. Chock the other wheels. Put the Tranny in neutral. (Engine off for safety.) If the center diff. is open, the raised wheel will rotate freely. If it's locked, it won't. (There may be 10-20 degrees of slop, but it WON'T rotate.)
So, how about just pushing the button in your driveway; as you say, the light is almost guaranteed to come on right way, yes? Then shut down the vehicle and perform the above test.
Inquiring minds wanna know!! :D
Curtis
Kalawang,
Curtis
Don't even need to start the motor, turn the key on and hit the switch. Even if the light doesn't come on the actuator motor will run, winding up the wait spring, when one of the driveshafts are turned it will provide the needed differential rotation and will lock.:D
Kalawang
Just to make sure you are hitting the CDL switch that lock the center diff lock in the transfer case and then you are turning the knob to the left of the steering colum to engage the front and rear selectable lockers.
Mark
I get the idea he doesn't have factory (axle) lockers.
-Spike
Diff locks
1. The center diff lock MUST be engaged to get the front / rear lockers to engage. Doesn't matter how you do it, CDL switch or engage Lo Ratio.
2. The center diff lock is physically engaged when the light on the dash comes on there is a sensor switch for this on the transfer case.
3. The rear / front diff locks attempt to engage as soon as they are selected. The dash light will flash until they are physically engaged.
4. Due to the design of the diff lock system they will not engage untill the splines line up allowing the selector fork to slide the locking collar. This means that the wheels have to move relative to each other to align the internals for operation. Same same in ARB's etc.
5. There is a know issue in the Diff Lock Sensor Switches. They get dirty and do not indicate the locked state sometimes even when the Diff is locked. They can be cleaned.
6. When you switch off the Diff locks (any of them) there can be a delay in them releasing as they have to unload to allow them to release. I almost always hear mine click out of lock.
I don't have factory or any lockers more than the CDL and it does not come with more than the off on button and the indicator light.
Yesterday I again tried activating my CDL in high and the damn thing actually activated and it became pretty near impossible to turn. I had to do the back and forth thing to get it to disengage. Not really a great deal of time but I was in a hurry to a meeting and the thing actually engaging at that moment was shocking. Rather disgusting that it happened as I was already at the point where I suspected past happenings had been my imagination and the CDL button was nothing more than a light switch. It's such a rare event.
Earlier today I tried it again and all I got was normal driving. In both cases the light comes on. I looked at the cost of ARB's and turned into a white guy.
I think I'm going to have to work with what I have for a while longer, possibly a very long while unless I turn a very good contract. Anyway, I have never gotten myself stuck so far and if I have to go somewhere truly dicey, I can always get a set of tire chains.
Kalawang
Kalawang
I get the sense that you think ARB lockers can replace your CDL, that is not the case, the ARBs are for front and rear differentials only. The center differential is essentially another term for "transfer case", in the 80 series.
The only time you should notice much bind when the CDL is engaged is on full (or nearly) steering wheel locked to one side, turns, on pavement. I suspect everything is working fine, but you are not clear on how the system works/drives.
I highly suggest you read the faq especially the section on differentials, diff locks and 4wd/AWD, before going any further. After that, if you have questions, please post 'em up and we will try to help.
C'mon, man; do the fricken driveway test!! If you honestly tell us that the light's on while you're sitting there endlessly rotating the wheel, then we'll believe you; other than that, it sure seems like most folks here are simply going to assume you don't know what you're talking about.
You might have the solution for me there. Yesterday, I clicked the button while backing out fo my driveway and that requires a full turn of the wheel, and that's when it locked. Today as is more common for me, I pressed the button when I was already out on the street. However, even when I made a 90 degree turn at the corner, binding didn't occur. Swerving from side to side also didn't do anything to my steering or handling.
Regardless, tomorrow I'll take a bit of extra time and press the button before backing out of my driveway and if it doesn't bind, I'll repeat a couple of times to see what happens. If my CDL is OK, I'll be one happy man.
BTW, I know that ARB's are not a replacement for the CDL. It's superior and I only looked towards it as a better alternative to the CDL. If mine were broken and repair so costly as is pretty normal for Toyota parts and repairs, then an upgrade even if a bit more expensive, would hurt less.
Kalawang
Kalawang
Sorry to belabor this point, but it seems you are still misunderstanding, the ARBs are in no way superior to a CDL. You can not upgrade a oem CDL to ARB, this is physically impossible, as an ARB locker goes in an axle, and the CDL is in the "transfer case".
To give you an example of the magnitude of your misundertanding, it would be like saying: "If my transmission goes bad, I will just replace it with a new upgraded axle".
A CDL locks your front and rear drive shaft together, the ARBs are for a front and or rear differential (axle), and lock both sides of an axle together. Without the CDL, the front/rear lockers will not be nearly as effective, and are a waste of time/money, IMHO, if the CDL doesn't work.
I followed Firetruck41's instructions and was able to feel the bind each time I made a full lock turn. I actually disengaged it three times and re-engaged it every time.
Firetruck41, thank you for finally finding a way to get through to my very dense mind. Likewise thank you for explaining why my plan to forget about repairing my CDL if it were broken and going straight to ARB's would not have worked. Seems to me that would have become a genuinely painfull financial mess for me if I had gone ahead. Thankfully, my CDL is fully functional and a lot more reliable than I had thought. All I have to do is turn the wheel to max and the thing is clearly engaged.
I'll have to try it out on a dirt road one of these days and maybe actually join some off road jaunt. It's just a thing I'm not attracted to as the only thing I ask my 80 to do is to get me to the places I need to get to and get me back out before the sun sets. I used to use a lancer for this but that got old real quick during the rainy season when the barrio roads became very muddy.
Firetruck and all others, thank you again for helping me out on this.
Kalawang
Glad to help you understand. :)
This is an impressive thread for no other reason than the patience shown by both sides of this CDL / ADL (axle diff lock) clarification.
I<3mud!
