Center Diff lock
What's your data for this? Just a gut feeling? Personally, I wouldn't either, but I'm pretty sure lots of folks here hit it at anything up to and including hiway speeds.
Curtis
Gut feeling, I guess. All the locker info stickers I see in Taco's, LC's, and other Toy trucks say not drive above 5 MPH with the lockers engaged. Figured it applies to the center lock as well. As for highway speeds.....I'm afraid that a driveshaft will break free and fly across the road. :o
I've engaged the CDL at 20-30mph many times with no ill effects/grinding/etc.
Gut feeling, I guess. All the locker info stickers I see in Taco's, LC's, and other Toy trucks say not to engage the lockers above 5 MPH. Figured it applies to the center lock as well. As for highway speeds.....I'm afraid that a driveshaft will break free and fly across the road. :o
In most of those, the drivetrain may not be moving already. What would be bad is to engage any locker with a tire spinning madly.
-Spike
The door sticker in my junk says; do not drive more than 5 mph with the lockers engaged.:rolleyes: It's talking about the axle lockers and is probably lawyer speak, due to the handling differences. The CDL has much less handling effect and see no mechanical reason why all of the lockers couldn't be run at any speed, other than the bind load wear if run long term.
My main use of the CDL switch is the lazy locker user syndrome.:D A lot of our trails have an obstacle, then relatively easy going, obstacle, repeat. I setup the lockers for the first obstacle, as soon as I clear it, hit the CDL switch unlocking everything, at the next obstacle just hit the CDL and everything locks, repeat.:D
Curtis
I have the suspicion that for a lot of the people who hit the diff lock switch, the diff lock is NOT locking. I get the light, but not the lock. At least, not for a while, most often a long while. When it does lock, you feel it. Most other times, I'm still in AWD.
It's what makes genuine selectable lockers like the ARB so attractive. The Diff lock needs a lot of excercising to become more selectable and even when you get it to working reliably, you're still pretty much out of business when one side hits the slips.
Make no mistake. I like having the diff lock as an added option. However, it would be a mistake to think it's going to save you all that often.
Kalawang
If you have the light, you have the lock. Toyota uses sensors that light the lamp when the locker is actually locked, rather than just when the locker switch is turned on. The CDL light will not come on at all unless the locker is engaged. The axle locker lights will flash when switched on, and stay solid when the locker actually engages.
If you take apart one of the actuators, you will see what I'm referring to. Light on dash = locked diff. The sensor senses when the actuator moves the locking collar to the engaged position. I suppose it's possible for the collar to be broken or the rod it slides on to break, but then the locker would never work.
-Spike
-Spike
That's also what I thought until my diffs actually locked on me. When you're ;locked you get the chirping and steering is a job and a half. We both know that. I got that even in High. However, I do get the light in High and Low ( itsy bitsy shift lever ) and no problem steering or turning or chirping. It takes a while to get the lock unless I've been excercising the diff lock. I actually took my 80 to my most reliable mechs to have the actuator serviced but they refused because it was apparently in good working order. My diffs do lock, but not always right away regardless of the light.
Unless I got myself a bad setup, I have to conclude that most times the switch does not necessarily lock immediatly and you're still in AWD. There really is no mistaking the lock.
Kalawang
Kalawang
Your system may be defective, the switch does not necessarily lock the cdl immediately, but the dash light for the center diff will not normally come on until the diff is actually locked.
Kalawang
Apparently there is. It's physically impossible to have the light on without the diff locked. When you hit the switch, it powers a motor which winds a spring. The spring holds tension and pushes on a fork. The fork moves an engaging mechanism. When the engaging parts line up, the fork pushes the mechanism together, locking the differential. The sensor for the dash indicator is triggered when the fork moves into the locked position. The fork depresses a contact switch on the sensor. The only way the sensor is triggered is by the fork, and only when the fork is in the locked position.
It is possible to have the light stay on due to a faulty switch, or not come on at all. If the light comes on when the CDL switch is depressed, the locker is engaged.
The diff may not lock immediately. It sometimes takes a few revolutions of the driveshafts, and they need to move at slightly different speeds for the locker to engage. It will lock faster if you're turning. When it does lock, the light will come on. When the light comes on, your diff IS locked, regardless of what you feel.
I don't get the 'chirping' from the tires and difficult steering when my center diff is locked. Those things only happen if you bind the drivetrain by turning with locked diff(s) on pavement. I have to make some pretty long, tight turning maneuvers to feel drivetrain bind with only the center diff locked, and steering is only affected slightly. Lock the front axle, however, and steering becomes damn near impossible. When I'm in the dirt, I can't feel any steering difference at all with the center diff locked vs. open.
-Spike
I wasn't aware of ARB's CDL?
BS. There is no "slips" it's a gear, spline locker, no slip is possible, ether it's locked or not.
BS. If their working properly, they work every time, if not the actuators need to be serviced and/or replaced.
... I actually took my 80 to my most reliable mechs to have the actuator serviced but they refused because it was apparently in good working order. My diffs do lock, but not always right away regardless of the light...
Time for a better "mech" if your stuff isn't working it needs to be serviced. I had some pretty good battles with mine, so now have a pretty good understanding of how they work. If you don't need them it's hard to get them to lock, if you do need them (wheel slip) they will lock if working properly. The rear only has 5 splines so it the hardest to lock when not needed, but when needed it only requires 20% of one revolution of differential wheel slip to to lock.
I routinely drive into an obstacle with some or all of the locker lights flashing, safe in the knowledge that the wait springs are wound, applying pressure to the shift forks. If/when lockers are needed, wheel(s) slip it (they) will lock. There have been times where I have cleared an obstacle with a light still flashing, I didn't need the locker, there was no differential wheel slip.
... It's physically impossible to have the light on without the diff locked...
Only way that I know of for it to happen, a wire shorted to ground. Been there, have the shrink wrapped wire.:D
Spike,
Thanks for the details on the CDL.
Truly I get the light immediatly as I press the button but not the lock. This happens on pavement because I keep trying to activate it as I leave home just so I get to excercise it. Never long enough to do damage, but getting the lock takes a while, if at all. More often than not, I just give up and go about my business. Thus the " chirping ", though I would also feel it in the steering wheel because I'm on pavement. It's easier to do it near home than to go out looking for a vacant lot or a dirt road.
Tools,
The " slips " I spoke of were those occasions when only one side of an uphill road is slippery and one side of your ride is on it. As I understand the theory, even with a diff lock the power goes to the wheels with the least traction and that would pretty well put you out of business. It hasn't happened to me yet but I saw a clip somewhere on the net demonstrating the effect using rollers. Pretty well discouraging until you realize that most times all your wheels are pretty evenly placed.
The ARB's I spoke of are full selectable lockers. Much more reliable with the 4 planetary gears as against the two planetary gears my stock 80 has.
There is a pretty audile thunk or click or however you would describe the sound when I press the CDL button and the diff lock indicator lights up. I do this just outside my home on pavement but the steering doesn't seem to be affected and my tires don't chirp when I turn. Yet there have also been time that it did and the difference is very significant. You could miss it, I suppose, on a dirt or sandy road but I doubt even that because steering feel is affected. Not on pavement. On pavement there is no missing the lock.
At this point I do believe that my CDL has a developing problem and I might have to force the issue with my mechanic to pull it apart and check the parts. I am driving a pretty old 80 and probably have some wear there. However, it might be more cost effective to go ARB if I have problems in that area. I'll have to look into my pocket and see what I can afford.
I'd like to thank both of you for your opinions and the information you've generously shared. They've given me much to think on. I'd also like to apologise to Mark Davis for hijacking his thread and shall try to be better behaved in the future.
Kalawang
Spike,
Tools,
The CDL doesn't have too much to do with one side of the rig vs. the other, it has to do with sending power to the front and rear. With the center diff locked, both front and rear driveshafts will rotate at the same speed, regardless of traction. If the front and/or rear axle are locked as well, then the left/right axle shafts on each axle will rotate at the same speed, regardless of traction. So in you example of rollers, if fully locked (center/front/rear), the 80 will go up with no problems and no spinning out.
Kalawang
I think you are confusing CDL (center differential lock) with front/rear lockers, as there are no ARBs available for the Center diff (AFAIK).
The ARB's I spoke of are full selectable lockers. Much more reliable with the 4 planetary gears as against the two planetary gears my stock 80 has...
Kalawang
I wasn't aware that Toyota made a 2 pinion locked carrier for the 80, US spec locked 80 carriers are 4 pinion.:confused:
Kalawang
I see that you are trying to back out of this discussion gracefully, without getting angry at me or anyone else. I appreciate that. I'm sorry that I can't seem to do the same and keep trying to force you to see things my way. It's a fault I have, and I apologize for it. I have to try again before you go out and spend a bunch of money.
I've given you all the information I have on the CDL. I can't get you to understand the function of the light, and that the fact is that your CDL is locked no matter what you feel. Let's try with the axle lockers.
The factory e-locker works virtually the same way the ARB does. It is fully selectable- open or locked, no in between. When it engages, it locks the two axle shafts together as one. There is no slippage possible. The only way one wheel is going to slip is if you break an axle shaft or something equally devastating. The only differences are that the e-locker uses an electric motor to move the locking fork, while the ARB uses air pressure to move the same fork. The ARB has a higher spline count on the locking mechanism, allowing it to engage with less difference in wheel speed. Make no mistake, that doesn't mean the e-locker 'slips', it will lock the instant one wheel moves less than 1/5th of one revolution more than the other wheel. On the rear axle the ARB also locks the two axles together in a different place on the carrier than the e-locker does, but the net effect is exactly the same.
The ARB has advantages and disadvantages compared to factory e-lockers but selectability, pinion count and full lockability are not among them.
I would highly suggest you do some research with an open mind. I don't know if the FSM has diagrams of the inner workings of the locker mechanisms, that might be a good place to start if it does. Seeing the inside of the mechanism and axle would be ideal. Maybe someone local to you is planning some teardown. Or, perhaps someone who's knowledge you trust can explain better than I. All I can say is I've seen the inside of these things with my own eyes, taken them apart and put them back together.
I will agree not to hassle you if you promise not to say anything alluding to the CDL not being locked when the light comes on, or suggesting that the lockers are not fully selectable. You are welcome to believe whatever you want, but with all due respect, you're wrong. :D As far as hijacking the thread, I believe we're still discussing the CDL and associated systems, and so far it's a civil discussion.
-Spike
Spike, Tools,
Clearly we have some differences here.
Tools,
The planetary gears I referred to, two of them, are apparently two of the four gears you refer to. The other two gears, a little larger it looks like, are what I call sun gears. So, for me, two planetary gears and two sun gears, for you, four. I believe what I call sun gears are sometimes referred to as spider gears. However, I have no idea of what you mean by pinion locked. The only pinion I can identify in the carrier is the pinion shaft. Aren't pinions essentially fasteners of a cylindrical shape ? At this point I suspect you are still speaking of the four gears but am far from certain. I do my best to understand these things, but there is so much of it.
Spike,
I do not accept that my diffs are locked simply because I've lit up the indicator by pushing the button. I do accept that the actuator is trying to engage a lock on the diff, but it isn't always immediatly successful regardless of the light. You are correct that there has to ba a degree of difference in the turning of the wheels for the diff lock to engage but that is not always an immediate effect with the pressing of the button and the light coming on. We shall have to agree to disagree here.
My example of the one side slippage was wrong and not applicable to the engaged CDL. You are correct that with the Center Diff locked, power is equally applied to all wheels, at least for as long as the Diff Lock can hold. In my example I would probably lose some speed and maybe a little handling, but the Toy would still climb. In AWD it would not.
Do try to understand that I am enjoying this discussion and am not trying to back out of it, gracefully or otherwise. For me, this is all instructive and I do appreciate your willingness to share your point of view. I believe there is no contention regarding the ARB air locker or the E-Locker. I would use either, the cheaper being preferred provided it was reliable, if ever I determined my current set up had become in need of repair. It would be an opportunity to upgrade without waste.
Kalawang
Kalawang,
You were right the first time: Suppose you're going up a hill where for whatever reason, the (say) left track is *much* more slippery. Even with the center diff. locked, it's entirely possible for all the power to go to the front left and rear left wheels; hence, no progress.
You are correct that with the Center Diff locked, power is equally applied to all wheels,...
No. Equally to both driveshafts. Not equally to all wheels unless front and rear differentials are locked.
Curtis
Spike, Tools,
Spike,
Kalawang
Yep, we will. To be clear, the light does not light up simply because you push the button. The light comes on when a sensor determines that the diff is locked, just as the lights on the axle diffs go from blinking to solid when the diffs lock. But whatever. Yes, there is sometimes a delay in the engagement, but the light reflects that delay. Very rarely in the case of the center diff lock though, because there is very rarely any significant delay. Several times I have hit the CDL switch and not had the light come on immediately. Of course, I was stopped at the time. Usually it will engage immediately even when stopped, but there are rare occasions when it doesn't. The light, in those cases, does not come on. But, obviously you have your mind made up and no arguement will persuade you otherwise. I look forward to the time when you have a chance to see the innards of a diff and actuator, until then I've said all I can say.
-Spike
