Center Diff lock
I just added the center diff lock button and did the 7 pin mod on my 97 Landcruiser. Can I switch from All wheel drive to four wheel drive while moving or do I want to stop befor hitting the center diff lock button.
thank you
Mark
The truck is always in 4WD. The center diff lock causes all 4 wheels to be "locked" to each other. From what I have read there is no problem engaging it when moving.
In mine I disengage it prior to turning and I don't engage it at any real speed.
Not to say there's anything wrong with that, my own practice is to engage it when I leave the pavement and disengage when I return to pavement, at whatever speed I'm at. There is at least one regular on this forum that runs the CDL essentially full-time, on or off pavement, with no reported damage- although I wouldn't do it. I don't know what the 91-2 manual says- those are the years that got the diff lock switch as standard equipment. That would be interesting to know.
-Spike
I have been wanting to do this (mod 7), can you describe the process and post a few pics to illistrate? thank you
AfricanToy
I went to Slee Offroad's web site for the instructions for this mod. There pictures and write up were very helpful.
Mark
OK...so if this is correct: when I disconnect the blue/black wire then the CDL will lock without being in Lo? but is there another switch that controls this locking and unlocking?
AfricanToy
No if you disconnect the blue/black wire it will let you switch into low without locking the center diff automaticly. You would then need the center diff lock switch that is used to lock and unlock the center diff. Here it is with the intallation instructions
http://www.sleeoffroad.com/products/products_switches.htm
Mark
Mark
Thanks....now I get it.
I will order the switch from Slee, install where the terminating plug is located? and hopefuly it will work.
ok so i'm looking to purchase an 80 and trying to understand the lockers. I have driven one with the circular switch to the left of the steering wheel on the dash. I did not see a CDL switch? is this the same switch? do some vehicles come with front and rear axle lockers but not the CDL?
All 80s have CDL, but in the 93+ there is no switch, it just automatically engages the cdl when in "Lo". The front/rear (the circular switch you saw) was optional on 93+, and for a unmodified vehicle, it must be in "Lo" (cdl locked) before the front/rear lockers will engage.
If you have a CDL switch and do not do the pin7 mod you can lock the transfer in 4HI. If you have the circular Front and Rear locker switch, a CDL switch and no pin7 mod, you can engage the lockers in 4HI along with the center diff.
The advantage of doing the pin7 mod is that you do not have automatic engagement of the center diff lock and that is a feature that I like if I am on dry surfaces like sandstone in 4LO and don't want to have the transfer case bind up.
Did you like this truck?
Dave
These guys may have failed to mention that while '93 and later U.S. 80 series vehicles did not come from the factory with a CDL switch, the switch is available from Toyota and other vendors and can be simply plugged in to the factory wiring harness with ease.
-Spike
-Spike
My 91 owner's manual doesn't say much: "To shift between unlock and lock modes in "H", push the center differential lock button." :rolleyes:
There may have been more info on the sticker on the glove box, but I pulled that off a long time ago.
Curtis
-Spike
Just 93+ with Anti lock did not have the switch. 93s with out ABS have the switch.
You should be able to switch it while moving... I wouldn't be going faster than 5 MPH though.
There was a sticker? ;p
MY 92 80 ahs the push button on the dash and I used it alot driving in the snow to the ski resorts fro avalanche control(before the plows hit the road and I switch it at 15 or less and have no problems. The past two winters.
