............ When in 4L mine locks me out of OD ..............
Anyway if I can get OD in 4L then that would pave the way for Marks t-case gears...
Electronics aren't my strong suit...so if anyone has a thought about this I'd appreciate it! 100TD?
It's all too long ago!
IIRC the low range detection switch on the transfer will send the signal which changes the shift points for low and high, which will also not allow overdrive. (This is the one you are thinking of unplugging)
IIRC, the pin 7 mod breaks(or makes) the signal to the 4WD control ECU that automatically locks the CDL when LR is selected. The signal still goes to the Transmission control ECU and changes the shift points.
SO I expect you would need to arrest that signal.
IIRC a Euro member of this forum did a write up on ABS control in normal, CDL, and LR modes and did a slight modification to the pin 7 mod and actually swapped pin 6 & 7 and put them back (or something like this) and disabled his ABS when CDL was on or something.
Do a search for that and have a read of his findings and I think you will get a handle on it, this may have held HR shift points as well. Just have a look at the wiring diagram and follow the LR switch to all it's ECU inputs. I expect if you break the connection to the Engine control module it will work. But see below.
So, if you interrupt the signal(or supply a positive or ground signal) to the tranny ECU you should be able to select OD in LO, easily doable.
However you will need to wire it to a flashing LED as a reminder that you have it activated.
You may get a result from disconnecting the LR switch or fitting a bypass switch BUT,
the reason for the pin seven mod was to do away with disconnecting this switch and allow everything else to function normally. By disconnecting or adding a switch I expect you will get OD back but lose other functions such as indication and not have LR shift points.
Give it a try.
This time of year I can't scan over all the drawings but if you read the post I mentioned you will understand which signal wire needs to be stopped or modified with a switch. (The Black/Blue wire)
) . So with Marlin's gears then 4th/OD + 4L would be very close to the engine RPM's I now have with stock t-case gears when in 4L and 3rd. Wouldn't use it alot...but nice to know I could.
