The CEL should blink for a second when every engine start! Is that right?Someone cut the wire to it or removed the bulb.
NO. When you turn the key to the ON/RUN position BEFORE cranking the starter, the CEL should be on.The CEL should blink for a second when every engine start! Is that right?
Thanks. I understood this. now the problem is I never saw the CEL light on when turning the key to ON position!NO. When you turn the key to the ON/RUN position BEFORE cranking the starter, the CEL should be on.
If the CEL remains on after the motor starts, that indicates a problem.
If the CEL is off after the motor starts, then there is no problem.
Does the engine run?Thanks. I understood this. now the problem is I never saw the CEL light on when turning the key to ON position!
The 80 runs very well!Does the engine run?
Is it easy to open dash for checking the bulb? ThxGotcha.
IF your vehicle starts (engine runs) then I'd look to the bulb being out in the dash (burned out or removed).
IF the vehicle will not start...then check your fusible links at the battery.
forum.ih8mud.com
