CEL after splashing through a mud puddle.
Gilbert AZ
My check engine light came on after passing through a mud puddle five or six times. I do hate mud.
O2 sensor plugs wet
Checking the code is a good place to start.
X3 on checking the code. But from my experience it's a wet O2 sensor. Unplug it, dry it out and put some dielectric grease in there.
Water inside the spark plug tubes will also throw any of the 301-306 codes.
Yup, it sure can. But, in my experience on nearly a dozen different rigs that have got this code after plying in water, every one of them had water in the dizzy. The #6 plug wire is at the lowest position in the cap and it only takes a small amount of water to fowl it out. Engine heat usually cures the problem if you just keep driving. I usually plug the top one of 3 holes in the dizzy to prevent this. Has worked 100% for me with no corrosion or ventilation issues. John
Thanks all. I went to AutoZone and got the meter. The display told me that the number four cylinder had a misfire. I simply cleared the codes, the check engine light is gone. Running like a champ with no check engine light.
Ahh, feels good to have that annoying light gone.
Nothing good ever seems to come from playing in mud......
