I have a 1991 cruiser and the CDL is locked in the ON position.
A little history...
I bought the truck and it had been sitting for 5 years. The transfer case had a hole in the case so it needed to be changed. I purchased a case from another Mud member and installed it a week or so ago.
When I tried to actuate the CDL it would not engage. I even tried shifting in low/hi/neutral etc.
I drove it down the road and assumed the CDL actuator was busted so I parked it. A few days later I started the truck and noticed the CDL indicator was showing to be locked....
I can not get the unit to unlock now. I've tested the indicator switch on the case and the dash switch and both are working fine. I even had a friend work the button on and off while I tapped on the actuator with a screwdriver. Still no sound from it.
I removed the actuator from the old case hoping I could plug it up (holding it in my hand) and see if it worked but it wouldn't work either.
Keep in mind I'm not completely sure it worked to begin with as the old case housing had a half dollar sized hole busted in it.
Any ideas?? I noticed a ground strap that was broken off under the vehicle and plan to replace it soon.
A little history...
