CDL stuck "ON"
UPDATE :
If you find this thread down the road refer to the CDL Actuator Fun link posted above. This has all you need to know...
Now on to my specific problem....
I took my "spare" actuator apart and it had a screw that had come loose from the brush holder and shorted out the motor...I replaced the screw and cleaned up the armature and magnets and bench tested it with a 12v battery and everything functioned properly.
I noticed that I now had a blown fuse in the 30A "Diff" spot....before replacing the fuse I tested the motor on the transfer case by "hot wiring" 12v and ground to the motor....to my surprise it actually worked....
I did this half a dozen times and plugged the unit back up to the wiring harness, installed a new fuse and now everything functions as it should..
The only thing I can make sense of is that the actuator had sit and "frozen" then by straight wiring the motor and working it a few times it freed up.....who knows...but it works flawlessly now...super fast to engage/disengage.
Good luck to all who might find this thread!
Case : CLOSED
UPDATE :
Case : CLOSED
My vehicle CDL is stuck on. I do not hear the actuator at the TC engage or disengage as the CDL switch is pressed or depressed. The DASH light is on indicating the CDL is engaged. The vehicle definitely is driving like the center diff is locked.
How did you hot wire the actuator motor while still attached to the TC? I'd like to apply power to the actuator independent of the CDL switch. My theory is 12 volts is not getting to the actuator.
Any help appreciated...thanks...
I could not upload photo to our conversation.
I'll post photos here...
Here's a photo of the connector to the actuator.
Im trying to understand which I should power to disengage the actuator.
Between pins 4 and 6,I measure 11.7v with ign on.
Between pins 4 and 5, I measure 0v with ignition on.
I got it to unlock by adding 12v to pin 2 (red) and gnd pin 3 (white). Reversing polarity to lock.
The center differential lock control relay went bad.
No power was getting to the actuator.
For now, I've disconnected the CDL switch and went back to the stock setup. Also removed the 30A differential fuse until I can get a replacement relay.
Another option is to bypass the CDL switch by adding a momentary switch direct connected and fused to 12v.
Thanks tacoma2002!
Is the relay confirmed bad? A poor connection at the limit switch is more common.
Not confirmed bad. It could be a symptom of something else. I still need to pull it and do further testing, but I did not measure 12v to ground on either pin 2 or pin 3 with the CDL switch pressed or depressed. No actuator movement could be heard.
The limit switch you are referring to is connection C2 on the diagram? Hotwire locking and unlocking the center diff caused the CDL dash light to go on and off. Indicating the switch at C2 is working proper and the internal switch to the acuator is flipping.
I'm hoping it's not the relay but will need to find time to pull it.
