CCOT leveler block -- installation?
Central Maine
I realize that trying to cure the Cruiser lean may be a bit sacrilegious to some, but since I received a block as a present (along with a bunch of other Cruiser parts), I'm planning to try it out.
So far I have loosened the U-bolt nuts, but I have not removed them fully. Before I go any further, can any of you give me directions on the easiest method to install the block? Will it help to lift the axle, for example? Do I need special tools, or is what I am trying to do pretty simple? (Right now the body is not on the frame, so if I mess up, I won't be able to drive anywhere to get it fixed.)
Thanks.
Do you have "the lean"? If you don't, don't install the block. If you do have "the lean", install the block on the high side. If you have enough threads on your U bolts, just loosen until enough space is open to slide the block in between the springs and axle. Once the block is in, retorque the U bolts. It is as simple as that.
With that said, the safest way would be to have the frame on jack stands. Loosen the U-bolts and then jack up the axle. That way, you don't risk having anything fall on you in case you loosen the U-bolts too much.
Good luck! :cheers:
If you have a lot of lean it wont fix it. Also if you want to install the center pin you will have to get a little creative. I was able to do it while leaving the springs attached using a c clamp to hold the springs together, jack stands , and jack to press the springs in just the right way to get it all lined up. A real fun time, Air impact wrench was the only thing that I could not do with out. Dam those rusty bolts.
My springs were still held together by the clamps on the springs. I did this awhile back. I thought this was as simple as taking off the Ubolts, taking out the center pin put the leveling block on the bottom of the stack between the leaves and the axle and put on your new center pin, and maybe new Ubolts. Trim off the extra on the center pin.
Thanks for the quick replies.
Yes, I do have the lean on the driver's side. I'll use your suggestions and try to put the leveler block on the passenger side tomorrow.
That plate came with a 3/8" - 16 socket head screw. The original center pin needs to be removed and the new pin installed. The plate goes on top of the rear passenger leaf spring pack. I removed the U-Bolts and supported the axle so it was not resting on the spring pack. Obviously you need to also support the frame. This is best done with the wheel removed. You may have to drop one end of the spring in order to get enough clearance to pull the center pin. After removing the center pin, you may need to run a 3/8" drill bit through the spring pack to clean out any rust accumulation in the center pin clearance hole. Some have a lot of trouble clearing the hole through each leaf. I've done all four corners to install 3/8" center pins and had no issues.
bsevans, thanks for the additional suggestions. I was all set to continue the process this morning, but then I noticed that the spring perch (hangar perch?) was in bad shape. I need to take care of that area first. I am planning to bookmark this thread or print a copy so that I'll know what to do once I get the other stuff taken care of.
