I'm having a problem with the engine hesistating when you hit the gas - a big pause, then it pulls away smoothly. It'll pull smoothly if I'm really gentle when increasing the throttle. I've got a dual fuel setup - petrol & LPG (Propane), and it doesn't do it on LPG, so I can be pretty sure it's the carb. My first thought was the accelerator pump not working, but it's sending a pretty good squirt into the carb as you press the throttle. Is there anything else that seems likely? I guess it could be the accelerator pump not getting enough gas through (partially blocked)? Or could it be timing over-advanced? - it is quite a bit since LPG is slower burning & higher octane...
Any other thoughts?
Thanx
Any other thoughts?
Thanx
