car won't start, doesn't even click
Ive had this before, It was a simple blown fuse at the drivers knee, kept me stumped for days
Found 15A blown fuse (middle row below 7.5A), is there a fuse panel diagram to look at ? I tried spare fuse and it was blown immediately so I need to find the short (Not sure how to go about finding one in whole car)
Ok, disregard the alternator. Focus on the fusible links
These were good, though in bad shape (wear and tear, connectivity was good) and while removing them I broke a lid on small box which connects links to cables. I hope I can find that small box and new links I'll keep them handy.
Ok found the fuse box block diagram: It looks like I'm blowing "ECU-IG : Cruise control system". How should I find the reason for blown fuse? Thanks
ECU-IG fuse feeds the following:
ABS ECU
ABS Deceleration Sensor
Combination Meter
Cruise Control ECU
Engine ECU
Transmission Pattern Select Switch
Light Retainer Relay
Shift Lock ECU
Since this issue started when you installed the radio, I suggest retracing your steps.
ABS ECU
Combination Meter
Cruise Control ECU
Engine ECU
Shift Lock ECU
Thanks, but I have removed the new stereo further I've nothing connected in dash. I had checked car starting after installing stereo before putting it in place and adding dashboard cover.
I'm pretty sure while moving around in the car I've messed something, I can't seem to recall / figure exactly what it was :(
I'll keep you guys posted if I find something.
Thanks for links for fusilble links
Sometimes electrical mistakes can happen and get a loop connection which will keep on blowing fuses.
If you didn't touch it, leave it alone.
Trace back the connections you made already.
You're dealing with 20 year old wires. It is possible that the insulation fractured on a wire and is shorting against a part of the dash or to another wire. You obviously disturbed something during the install process. I'm not sure what you mean by "moving around in the car".
Am I correct in assuming that everything was working fine BEFORE you put the dash back together? If so, then you must have created a short when you put the dash back together. Follow the logical progression.
As Jon said, 20 year old wire. Messing with the stereo requires lots of yanking, pulling, and stuffing. Plus you got to move a bunch of wires around too! :rimshot:
It's VERY EASY to pinch a wire in there. Start unwrapping and looking.
Yup most probably this. That's why I removed all cables from new stereo and dash, I'm going to try looking through other connections again.
This is so stupid :( ECU-IG #9 15A fuse keeps on blowing , This thread helped me.
When I bought the car (2012), I cut the cable for phone and left the remaining cable in center console. There were bunch of things laying around in the console. Yesterday I shoved few more things in there and got phone wires shorted.
I guess I should do this: LX450 Phone Delete and route my new stereo wires in place.
