Can’t find problem
NJ SUCKS
Website
www.recordme.com
My 94 has been out of commission for over three months! I’ve had it to two shops
Both kept it for weeks on end but can’t figure out why it’s running rough and smoking...
these are both reputable shops I’ve worked with for years.
I really need someone who knows these great engines that could guide my mechanic or a shop in the New Jersey area that could do the deed.
Shop number two is now saying I may have to take it to this stealership to get to the bottom of it.
Any help would be appreciated
Thanks
What color is the smoke? What have they done to it to diagnose the issue and what have they ruled out? Could be as simple as a disconnected vacuum hose or as bad as a code red head gasket failure or worse.
On a more serious note; you were about a vague as possible so if you want some answers, I suggest you pony up some data.
What have the shops done to test this?
Coolant pressure test?
Leak down?
Compression test?
The list could go on and on. At this point I’m not sure what a dealer would be doing differently to fix your problem. They’re going to try the same deduction techniques a competent shop would use.
That said, if they aren’t performing the right tests to check into the problem, I would wonder about their competence.
Especially after a couple of weeks. If they are trying to diagnose it from the desk or while working on a another car, they probably aren't doing anything. Otherwise, they would be telling him that he owed them several thousand dollars. "worked on it for two weeks. Didn't get anywhere. You owe me 4 grand".
Those shops probably don't need the business and that's why they just told him to go to the dealer. Honestly, the best answer is to figure it out yourself. Start by jumping the EGR system to see if the problem persists. That eliminates a good chunk of the vacuum hoses.
Go from there. Go through each system and look for issues. Check the main engine wiring harness near the EGR pipe, too. It could be that it got scorched, very common. Fix the wires, re-wrap the harness and delete the EGR if you can, legally.
If that doesn't work, move on to the fuel system.
Of course check to see if you may having a cooling system issue that could be mixing coolant with engine oil as in the case of a blown head gasket.
I’ll share what I know; did’t want to over explain Since I’m not a competent mechanic myself
I’m hoping to either find someone who can talk directly to my mechanic or a shop in New Jersey that is experienced with these types of motors. :
Issues:
the smoke is white, it runs really rough/smokes first few miles . Strong gas smell injector was stuck open even saw some gas dripping on manifold
The first shop did what was suggested on here , check the harness , he did find damage and “re-soldered a wire”.
The truck ran fine way home from 1st shop.
The problem come back after the truck sat a few days(no smell though) AND shifting got haywire too :intermittent 1st (bad ground maybe?)
since the shifting has now also been affected would also point to something in the harness? bad ground?
Thanks everyone I’m really in disbelief none of the shops are able to sort this out
. I really miss my truck especially now that the snow is coming.
Might be a bad ecu? That is some very vague info.
I’ll ask Bill the service manager to write up the list of tests performed to put up on here Monday
Thanks all
I'd check the wire "fix" over anything right now. He may have fixed the wire, but didn't fix why the wire was damaged in the first place. That wire may have burned through again and taken out other wires in the process.
Don’t solder wires in the engine I’d use a splice, vibration and heat and crappy solder job will kill the connection, recheck wires and pull them off the egr pipe.
Any data is better than none at all.
“I cannot make bricks without clay.” - Sherlock Holmes
The harness would be a good starting place since it’s been tampered with. That said, in my experience, an injector stuck open would definitely have a smell, but the smoke I had was still white (two were stuck open on the trail, that was weird).
Get on a stool and get your head right over the wiring for a close look; follow the EGR pipe down to see what kind of shape the wiring harness is in. If the guy bungled the solder job (I agree solder should NEVER be used on a vehicle), then he may have screwed up some other wires in the neighborhood and it could be the cause of some of your problems.
Sorry that I don’t know of any shops out your way, but at this point you not only need someone who is decent with Toyotas but also decent at dealing with other people’s mistakes.
One second thought, if the truck is stock you might not need the stool. I’m used to taller 80s.
So it is shifting odd, well first thing I say is unplug transmission and drive it manually shifting, if it is ok , then it is a solenoid issue, and i would replace all of them, the gas smell can either be a bad gas cap or your canister, and maybe even both of them .
I've been soldering wires on my trucks for 26 years. Solder encapsulates and seals out oxygen which prevents corrosion.
Wires get tinned, soldered, and proper size shrink tubing is used. Never an issue, always a good connection.
Onur is not in NJ, but is not far away. Just a quick ride up the NYS Thruway.
Welcome to LCPC
I was told this too. Reasons given, the flux in solder contains acids (or used too) that corrode the copper and make it brittle, plus the joint becomes rigid. In some circumstances, this leads to snapped wires.
I think in most instances soldering and heat shrink is fine
Do you think this is better than using those little barrel splice fittings?
I am a 1 :banana: electrician but I need to get into my trailer wiring to see if I can get the lights to work and I may be installing an aftermarket stereo this year and I had heard some complain that the solder method can giggle loose with vibration. Do you try to splice the wires together first or do you just lay them next to each other and add the solder? I have a soldering gun and I kind of enjoy using it, but I am not sure which route would give the best results. Any thoughts?
Like with anything else, you need the right tools and practice using them. I've been doing component level solder work since the early 1980s, so I know something about technique.
Butt splices have their place and can be mechanically and electrically sound, but a proper crimp tool should be used.
In aircraft environments, solder is not used. However, my truck very rarely travels high or fast enough to see the same type of conditions. My concern is with corrosion and contamination.
Do you do anything to treat the wires to be sure there is no contamination? I have a couple bottles of CRC QD Electronic Cleaner that I was planning on using to get the wires clean enough to work on them and also to clean junction fittings as I go through the truck.
Could I spray that on before I solder? What about after? Would it hurt to rub a little dialectric grease around the area before shrinking the wrap?
Someone should tell this to Mr. T as they are about 10,000 soldered connections in your truck right now. Every PCB and wire to PCB is a soldered connection.
Rosin flux which is used with copper to copper connections is not acidic and is purposely designed to be left on the connection when finished without making the metal brittle. Yes, soldering requires some skill and a bad solder joint is possible and dangerous, but just flat out saying they should NEVER be used isn’t great advice IMO.
As a EE that literally designs and works on electronics for avionics systems, solder is definetly used in aircraft! The FAA and others provide guidelines to ensure that soldered connections are reliable.
