I’ll ask Bill the service manager to write up the list of tests performed to put up on here Monday
Thanks all
Did Bill The Service Manager ever give you a write up?
I'm guessing no.......
In order for ANYONE to diagnose what you are asking, you need to clearly define the issues you are having.
1) It runs rough
2) It is spewing white smoke
3) Shifts poorly
When do these events occur?
Only on start-up? Or after it has been driven about 10 miles? Does it go away after it has been driven 25 miles?
Is the smoke only on start-up for a few minutes or does it continue to billow clouds of white smoke at idle or at speed?
Is the engine fully warmed up (10+ miles) and still shifts poorly or is that only noticed when cold?
Have you checked for loos of coolant in BOTH the radiator and overflow tank?
Have you checked the engine oil for milky looking oil?
Have you checked the coolant for milky looking coolant?
What is the service history of the truck?
Mileage?
Has the Head Gasket ever been replaced to your knowledge? (If you don't know....how many owners have there been and how long have you owned it?)
When did you last install the following items:
Distributor Cap
Rotor
Plug Wires
Spark Plugs
Valve Cover gasket
PCV valve
PCV Valve grommet
Intake hose
Radiator cap
Checked the coolant
Checked the oil
Changed the oil
There are SO many simple things you can do with NO MECHANICAL ABILITY that will help you get answers. But YOU have to do them. If you don't know how....ASK!
