Turn vehicle On, shift transfer case lever to LO (engages Center Diff Lock, CDL), shut vehicle Off, remove Diff Lock fuse (bottom right pink square fuse in dash fuse box), shift transfer case to HI. The CDL will remain locked as the CDL motor no longer is getting power.
Two orange lights should come on, lower left instrument cluster; ABS and Diff Lock, indicating ABS has been deactivated and the CDL is locked. The CDL will remain locked until you replace the fuse. You can drive the vehicle indefinitely in this mode with one driveshaft removed.
Never drive with one driveshaft removed unless the CDL is locked; you can burn up the viscous coupler in vehicles so equiped, but also the vehicle will roll even if the transmission is Park (unless the Emergency brake is engaged).
Above applies to 80 series with factory AWD.
