- Joined
- Jun 17, 2013
- Threads
- 36
- Messages
- 234
I have an 18” partner steel stove. Great stove but I have one issue with it...
I like to make coffee in a percolator which means once the water comes to a boil you need to turn the heat down low and let the coffee cycle through the percolator for a while.
The stove has no problem getting the water to a boil but it has difficulty staying lit on a reasonably low temp. To keep the flame lit I have to turn the heat up. Here is where I notice the problem, when I barely turn the dial the heat turns up too much.
Can I run a different regulator or do you all have any suggestions that would allow the burners to operate more efficiently at lower temps? I’m not worried about the heat on higher settings as it puts out more heats than I need when I cook.
