Cam's FJ60 Gets a Heart Transplant
Sounds like you'll be ready to swap that bad boy by about.... next weekend?
I got my parts order in today, but I'll be out of town next weekend.
You and Mark can come slap it in for me :D
That's not entirely true... I will probably go through brake pads and shoes more frequently!
First parts started showing up!
Twin stick kit since the t-case is moving but I don't want the shifter (now plural) to move.
Misc. interior parts...
I also got the Monte Carlo gas pedal today.
Shortest arm available (I think) and the only one with a straight drop.
Almost a perfect fit.
Here's the part#
Maybe I could rig up the clutch pedal for left foot braking for crawling :hmm:
I've read where the LS3 C6 Corvette exhaust manifolds are a nice fit. I found a nice set that are on the way, but not before I bought a cheap single manifold on eBay.
A side benefit is that the O2 sensor is right in the manifold for easy placement.
Gonna leave my old driveshaft flange-to-flange measurements right here for safe keeping.
I found this ball bearing under the truck after pulling a bunch of stuff loose. No idea where it came from, or if it was even from my truck.
Could be left over from my rear 3rd debacle. Maybe it would've made that Spartan work.... Nah.
Spring under trucks need a little extra clearance under the oil pan. The truck pan is probably fine for street I've heard of at least one guy who cracked the truck pan taking it off a sweet jump.
The solution is an F-Body Camaro pan. Gets you a few extra inches of clearance.
superchevyperformance.com sells the new parts at a lower cost than the going rate of clean used parts on eBay.
Also needed is the matching pickup tube, windage tray and dipstick.
Check out the sweet pan gasket that comes with the pan. It is way better than the $&?@%# cork gasket on the 2F.
I also got my set of exhaust manifolds. Turns out they are brand new!
In other news... my AA adapter and Lokar shifter were "delivered" yesterday, but weren't on the porch when I got home from work. So they were either mis-delivered or stolen :mad:
