James,
I'll take the other side. I say Powder Coat it. PC is NOT had to fix when you chip or scratch it, plus unless your going with some funky color, you can always touch up spots with a flat black. I've done it several times. As far as adding anything to it, if/when you get to it you can take the PC off with a grinder or wire wheel. You can then have the whole thing re-PCd or just the areas what you made the changes to. Although you'd be better off just redoing the whole thing since the powder is the cheap part and won't make much of a difference in the price, plus you'd have a thicker coat. If you rattle can it now and decide to PC it later, you'll have to sandblast it.
Good Luck.
Good Luck.
