Cage in. Coating options needed.
Utah
I just got my roll cage into the Cruiser.
I will be putting in a seat cradle and 5 pt harness mounts at a later time.
I have the capability to paint the cage myself using pro level equipment. However, I need to buy sand paper, primer, thinner, etc etc etc.
I can have the cage powder coated for $125 as it sits now.
The only reason I have any hesitations about powder coating is because of the later improvements I intend to do to the cage.
Should I just rattle can primer it, and rattle can it for now?
Should I paint it properly with a 2 part epoxy paint?
Should I say F-it and have it powder coated? Can I grind a few spots of the powdercoat for welding purposes, have the new stuff welded in, then the new metal powdercoated and the newly welded stuff powdercoated? Or for powdercoat does it all have to be stripped off?
Thanks!
Why you in such a hurry to paint or powdercoat it all now? I say hold off until you get EVERYTHING figured out & mounted. Then do the powdercoating. Rattlecannin' is for those who don't really care about long term rust prevention. Don't go the cheap route! I didn't have a source for a local powdercoater, so I layed on the POR15, primer, then a brushed on a coat of Rustoleum. So, almost all of my rig has 2-3 coats of paint......
hhhhmm....IMO, the rattlecan is the best solution....easy touchup, no added expense to repowder when you modify it later, no expense when you have to replace a tube and repaint etc....
I've replaced a couple tubes in mine....rolled/flopped it over 10 times....ground it against the rocks and had to sand the metal to ditch the slivers....
rattlecan rocks...
I shot mine with a gun... but we have done several others with rattlecan, a properly done job (meaning well prepped, quality paint, etc) will last a long time. I'm not really a fan of PC for the cage...
I rattlecan my crap because it works well in UTahs dry climate.
I don't pay a lot for powdercoating because I use my shiat and scratch it.
i used 4 cans of hammerite black on my family cage and it looks good, and you can modify and repaint any time. and there is no need to prime and can be used over slightly rusted area's.
who made that catge
Looks good I would rattle can it for easy touch up. There is some cool options now when it comes to rattle can paint. Can you give some info on the cage? Bill
Nice work on the cage!!
FZJFillmore said:
Is that the one Rock Logic did for you? Nice. Any bets on how long until you use it?
Rock Logic couldn't get to it until June, even though I had been speaking to them about it since February.........
Anarcy Offroad built it.
Probably going to be used at Cruise Moab 05.
Who knows?
Cage is 1 3/4" .120 wall DOM tubing.
It's tied to the frame in 4 places.
Anarchy Offroad (Brandon Gillen, who coincedentally worked on the Monster Garage Bronco build) built the cage.
It mateches the lines of the hard top and hard doors (which don't fit any more :mad: )
Overall I am really happy with the cage, and I think the price I paid was fair.
