C Clip missing
Western Slope, CO
I'm working on installing my new Aussie Locker :D and noticed that there is no C-clip on the (short)passenger side? looked for parts in the bottom of the housing....nothing. So is it possible to drive like this? isn't this what holds the axle in the housing? ok forgive my ignorance here just wondering where I should go to get new ones.
yeah you probably need that. what year is your i think i have some if you want just give me address
Be careful wmtnterror. That could be seriously dangerous unless you have a full floater axle in the rear. Or RDB--where at least the caliper will hold in your junk. Good luck.
i agree, there no way your drivin without one, and that could be it boxed
ok guys it's dark in there, yeah it fell down in there when I pushed the axle in....ok I'm a dumbass thanks for the help, just got her together gonna put some oil in and seal it up. Then it's time for a test drive!
I believe that classifies as a :doh:
:cheers:
Yeah I know, first timers huh. The good news is it's in and works like it should. I don't know why people complain about the noise they make, I did notice a that it seems to buck a little when I shift gears though :grinpimp: So I had to get a little muddy to test it out :D
I plan on attacking that issue next, came that way from the P.O. I think they are SOR's greaseable with a rough country lift. It rides like a damn tank too! anyone like to suggest some ways to correct this...thinking of a soa or some decent riding 4" lift. I haven't ridden in any other 40s so I don't have much to compare it to.
So are you driving with the shackles permanently inverted, or is this something that happens just every once in awhile?
I would start by unloading the rear springs and un-inverting the shackles. Then carry around some extra weight for awhile to try and settle the springs. Might try removing a leaf.
I have the same shackles, you can flip them so that they contact the frame to stop inversion sooner.
I like the ride of my Skyjacker lift, OME Dakkar is more $$ but a sweet setup.
IMO get this to where it will work, and then research and save money for a good SOA.
I would think it would ride like a tank with the shackles inverted. The rear axle would act like it was bolted to the frame.
Mine inverted when I first put my BDS 4" lift on but when I torqued down the U-bolts the shackles straightened out (still vertical but I haven't mounted the roof yet.) Most guys suggest around 200 lbs of sand in the back while you break them in.
Kevin
