Busted Manifold Stud
Santa Monica, CA
So this just happened. Any OG secret ninja tricks to get the rest of the stud out of the manifold? :bang:
It should be an open hole on the other side of the stud. I'd spray that side with some pb blaster, let it soak, then I'd start the engine to warm it up and put some wax in the same spot, let it get hot enough to melt and hopefully wick in the threads. Tap it lightly with a hammer and punch, then Vice grips on what's left, you may have to pull that pipe out of the way. If that doesn't do it only option is drill it out.
If you don't have a welder yourself, have a friend bring one over. 110v is fine. Get the downpipe out of the way. Find a nut large enough to slide over the remaining stud and weld the end of the stud to the nut. Loosen (and probably be amazed how easily it comes out) The high levels of heat will help loosen it from the manifold.
If you have the resources, this is the best method. After using it to remove a broken bolt and broken bolt extractor from the head of my LS, which is a notorious job, I won't bother with stud or bolt extractors ever again.
^^^^^^^^^ what @bloc said! ^^^^^^[
I knew needed a reason to get a welder at home. I'll give it a try. Thanks!
Don't worry if your welded nut breaks off just keep welding nuts on until you get the stud out.
Found some pics of the job for me. It's obviously different.. flush or under, into aluminum vs steel, the bolt is only 8mm vs your 10 or 12.. but the extractor that broke off effectively expanded it into the threads in the head. It was STUCK.
I had to do the plug welding trick twice.. once, then turn clockwise to remove the extractor.. then another CCW for the bolt. Almost no visible impact on the head.. just some carbon. Ran a tap in and back out.. good to go.
The search for a welder shall commence. And I'll be swapping out the remaining studs while I'm at at. Thanks for the tips.
Another option www.quikcenter.com
Used my set to remove several broken manifold bolts (not all on the cruiser). You might have to take off the pipe to get a drill in there but should be able to work it with the manifold still on the truck. After using these for the initial hole just get a tap drill for the bolt size and drill that sucker out. Avoid any extractors, they will just break off.
Welding is a great way to do it, and one I frequently use, but welding upwards at that angle is tough and getting a good bond to that stud won't be easy (moot point if you remove the manifold). BUT... your wife doesn't need to know that if you need a welder and if the welder doesn't work out maybe you need another set of tools too.
Removed two full studs, broke two studs. Hit them with MAP gas till they glowed cherry red and backed them out with a socket. The other stud the broke at least backed out about half way, so it's on its way. The other is still full seated. Now that the down-pipe is out of the way, I'll commence the welding method.
