AFAIK Toyota sells the whole assemblyJust to be clear, can you buy the new / improved shaft from Toyota or do you have to buy the whole assembly ($250-ish) in order to get it?
Yes. I don't know where my photos went, but the new part is thicker when comparing them. I replaced mine when it was 10 yrs old at 141k miles, have not doubled the time or miles yet... so can't say for sure, but it definitely looked like a better design.Is a new part an improved part?
Edit: Well it looks like I missed the next page where this question was answered.![]()
I believe that likely adds to it. I don't normally have mine locked either, but it was when my ignition broke. Although when it happened I didn't feel the snap, it just spun. - The old design was thinner in one area and just couldn't handle the torque being put on it.I don't usually end up with the steering wheel locked. Is that one of the things that kills these is turning the key against the steering wheel lock?
I joined the "busted ignition" club this past week. 2001 LX470. Same exact issue with broken camshaft in steering lock assembly. I searched around, and did not see any videos for this fix. So, I decided to make on with my brother. Here's the youtube link:
I hope this helps anyone doing the repair themselves. I also included the PNs in the text.
Thanks to everyone on this post who guided this repair. Saved me hundreds of dollars.
Theoretically? yes! Practically? not without a lot of custom modifications.This happened to me a few weeks ago at the worst possible moment. I destroyed the entire assembly and some more. I haven’t gotten it fixed yet.
My question is, can all that junk be eliminated and replaced with a push button?
There are auto security systems that have the chip from one of your keys that make it remote start with a key fob. Not sure how that works if your key portion and column lock are hosed though.This happened to me a few weeks ago at the worst possible moment. I destroyed the entire assembly and some more. I haven’t gotten it fixed yet.
Any modification to the procedure for replacing a fully intact shaft with an updated version? I’m curious if you have to loosen the screws on the white piece.Used this guide to replace my ignition switch rod with an updated version. Thanks!
That's exactly what I did. Not much difference, it is just easier to do! Yes, I had to loosen the white piece to create about 1/8th inch gap. Everything is easily accessible. Took me about 30 minutes start to finish.Any modification to the procedure for replacing a fully intact shaft with an updated version? I’m curious if you have to loosen the screws on the white piece.
Well, considering the steering lock was destroyed in the process of hot wiring it. I guess the hardest part is already done.Theoretically? yes! Practically? not without a lot of custom modifications.
I suspect you will need to either replace the security ring with some sort of radio receiver to bypass the ignition lock. Then you will need to physically cut out the steering lock or remove it somehow. The actual engagement of the starter just takes a simple switch that can pass on 12v but everything else is not that straight forward
Worth checking with them.Well, considering the steering lock was destroyed in the process of hot wiring it. I guess the hardest part is already done.
Is this something Best Buy techs can do?
Did you get it on yourself? I have questions.Just ordered one.....because you KNOW at some point you're going to need it.
Not unlike heater Tees, Booster Pump Motor, etc....(things that will leave you on the side of the road).
Thanks for sharing this. Some one should create a replacement made of proper steel instead cast with pot iron!
forum.ih8mud.com
