Bump stops for SOA
Silicon Valley
Hi,
What do you use to lower the bump stops after a SOA with stock springs? Any pictures please?
Thanks.
TD,
I took the rears, with their spacer, and moved them up front. They work well and are stock (I know how you like stock ;))
And for the rear, I acquired another rear spacer, and attached a pair of those 4" poly bump stops. They were expensive, but they were the tallest I could find.
like this
http://store.summitracing.com/partdetail.asp?autofilter=1&part=ENS%2D9%2D9104R&N=4294925130+115&autoview=sku
On the 55, I'm going to use a piece of 2X2 stock and one of these because it will be cheaper (you know how I like cheaper ;))
http://store.summitracing.com/partdetail.asp?autofilter=1&part=CEE%2D7024&N=4294925130+115&autoview=sku
PMK
Instead of lowering the bump stops I added a block to the top of the SOA spring plate to reduce the travel. Easy to make and works great.
pygpen said:
TD,
......and attached a pair of those 4" poly bump stops. They were expensive, but they were the tallest I could find. like this
FWIW if you go this route - I put some on mine - Google them as I found them cheaper than even Summit. I went looking for my receipt and cannot find it, but if I do I will post up as I found the company on the web just searching like "bump stops" if I recall. can save a few bucks I remember.
Pin_Head said:
I also used a piece of 2x2 inch 1/4 wall reciever tube to space the stock bump stop down. Fast, cheap and ugly, but effective.
That works for me.
