Building a new house and shop
So, ground water from above the finished product can flow in the valleys between the several concrete roof domes, correct? Is there slope built in on the dome tops to move the water flow where you need it to go?
Yes; the valleys between the domes are filled in, but soil is domed above the house on the long axis, so that rain water is shed to either side, towards French drains on either side. So, there is a French drain all along the bottom edge of the parapet wall on the outside edge of the house, and a French drain all along the very back of the house, at the bottom of the back wall, now buried in the hill. Both of those French drains empty into the creek that runs close to the south end of the house.
I'm afraid you are mistaken, sir. I'm certain that @1911 is giving careful consideration to thanking his lucky stars to be in the State of Texas!
And that's coming from me--having been born and raised in the Great State of Iowa; however, I'm damn glad to say that even though I wasn't born in Texas, I got here as fast as I could. ;)
Same here. I have lived in a number of states and some foreign countries as an adult; all had beauty and attractive features in various proportions, but overall we have come to appreciate Texas very much and decided some time ago to put down permanent roots here.
Nice FN-FAL!
Thanks, it is still my favorite rifle ever. Pretty much the Land Cruiser of self-loading rifles; old technology but robust design and construction, super reliable, works even when dirty, easy to work on, easy to field strip and clean with a minimum of tools.
I wish now that had bought more than one when they were still easy to find and cheap.
I can see that; however, I must confess that I'm more of an HK91/G3 fan. :cheers:
Well, you can call me a dumbass (and rightfully so), but I owned a pre-ban HK91 that I bought brand new in the box in 1979 or '80 for $600, but I sold it for almost 4x that during the Klin-ton "assault weapons" ban. Needed the money really bad at the time for a rebuilt engine for our family car, but I surely regret doing it now.
I jumped on the FAL parts set wagon when they were dirt cheap. Built a few and sold off last couple of kits for almost 10 times what I paid. Same with 1919 parts sets. Thought I was making a killing selling at $450 and now you can hardly find a decent/complete set for under $2k.
How’s the house settling in?
Really enjoying it, thanks. We have so much more room than in the barndominium, room for all the kids and grandkids to eat and sleep and do whatever when they come.
Still working on the outside of the house now, enough so that I haven't been reading or posting much in Mud these days. It reminds me that I need to update this thread with some photos though. Today it's raining here, so maybe I'll wait for a better day to take photos. But at least the rain gives a chance to catch up on Mud. Still doing a few more things on the inside also; putting up shelves, curtain rods, and there's still some permanent light fixtures to buy and install in the long back hallway.
The mrs. is working on getting more storage things out of the shop, so that hopefully I can get to and use my lift pretty soon; I have some severely-deferred maintenance/repairs that need doing on all of our vehicles.
A couple of current photos of what I'm currently working on:
Stuccoing the outside of the house.
The white you can see are the 3-1/2" expanded polystyrene foam boards that are glued (with Portland cement & STO primer) directly to the concrete walls. The stucco is then plastered over that (with same 50/50 mixture of Portland cement and STO primer) and using a heavy but fine-grid fiberglass netting, instead of the traditional chicken wire. This stucco does not have to be super smooth, as it will not be the finished surface - it is just a cementitious substrate to mortar stone to, and a hard protection for the foam boards.
On the parapet wall and overhang above the walls, smooth stucco will be the finished surface. It will be colored to compliment the stone on the house. I'm doing all of the stucco and stone on the house proper myself, but I'll pay the builder to come back and do the finish stucco on the parapet wall and overhang, because it needs to be done all at once, to get it smooth and keep the color even, and I want that to look nice and not like a first attempt.
The Portland cement and STO mixture is troweled on by hand, with a hawk and a 12" flat trowel. Working by myself, I can only use 2-1/2 gallons of the mixture at a time, because it starts to thicken and set by the time I am done with that much. You can add a bit more water one time, if necessary before the end of the batch. Usually I only do one batch per day, since I am still doing some consulting work also. Today I will probably do a second batch this afternoon or evening, since the weather is nice and there's no wind. The wind makes it more difficult to handle and correctly place the fiberglass netting. The netting comes in 150' rolls that are 38" wide, so I cut 8' lengths and put them on vertically. 2-1/2 gallons of the Portland cement mixture is only enough for a single 8' panel, but with enough left over to work on top and bottom edges, corners, window and door trim, and trimming around light fixtures and electrical outlets. Nothing is wasted - I can almost always find something to do with every last bit of the cement mixture. Scraps from the netting roll are used under the windows and other narrow bits.
My shoulder is sore just reading the process…
It’s a lot easier applying it to an 8’ vertical wall, than doing the 12’ high domes inside, where I had to work over my head all the time. Either way, I would not want to do this for a living!! But it’s OK, and satisfying to do when it’s your own house, and you can do it for just a few hours a day.
I finished the stucco on the entire front of the house yesterday. Started on the south end today. The south and north ends are much less surface are to do, since the house is long but relatively narrow. I’ll be pretty happy to be done with it (for a while, until I eventually get back to the parapet wall).
Another view of the stucco on the front. You can see the eight pallets of stone sitting in front of the house. I'll start putting it on over the stucco soon, when the ends of the house are done.
Such an awesome home.
Great job. I've been following since you built the shop.
I've been looking for your place on goggle earth but all I see is grassland. LOL
I have very much enjoyed watching the progress. Thanks.
Thanks!
Most of what we have is covered in trees, though a lot of them are Junipers (called "mountain cedars" for some reason here in Texas). If I live long enough, I would like to push over and burn a lot of the junipers. Some of them died in a recent drought; I didn't think it was possible to kill a juniper, other than sawing them down or pushing them over. There are enough hardwood trees (red oak, live oak, bur oak, ash, pecan, cedar elms, etc..) that getting rid of some of the junipers would give the hardwoods room to grow and expand.
We planted a few junipers as ornamentals in 1980 for the front walkway of the house… you can kill them pretty easily. Just ask my wife!! 😂
