broken frame repair
Atascadero, CA
well turns out i broke my frame in half and broke the spring hanger off the frame. fun stuff. ive been driving it like this for over a week now. man i love land cruisers. anyways my question is, do i weld a few peices of 3/8" plate on there to rebuild it or do i bolt on the plate? my goal is to make it very very strong because if its not its gonna happen again. i dont want to cut out the old stuff because i dont have the time or energy to do that. i have to get this done in one day.
thanks
-miles
i should also add that it broke right behind the solid spring mount in the rear drivers side. i can get some pictures if that helps anyone with ideas.
I seem to recall that the advice was IF you patch a broken frame, put on a long (+6" min either side of break) scab plate, 3 or 4 bolts on either side of the break, then weld outer edge of plate to frame, and weld up crack. seems like overkill, but, that is what ensures that it is not going to break(there) again.
Someone should have the ability to post some copies of pages from an early FJ40 factory manual that has Toyota's recommendations and procedures for repairing broken frames by welding on patch scab plates. They show patches cut so as to make all welds cross the frame at angles - never straight up and down, and the patches are always made to support the frame far out from a crack in both directions. In other words, big patch for small break.
there have been threads on the topic.
Obviously, if the frame is completely broke and/or the spring hanger has ripped out, it’s time to start looking for a new frame.
I've fixed a few 40 frames in that exact spot.
Some were so rusted that the rivets were nearly flush. We supported the frame with jack stands so that the weight would leverage the crack closed. The crack was welded and a long plate was cut to fit inside the frame rail - covering the new weld and rivets, and extending 6"-8" on either side of the spring hanger. Two plates were placed on the outside of the frame, on either side of the spring hanger, opposite the inside plate. The frame was sandwiched between the three plates with 3/8" - 4 in a rectangle on either side of the spring hanger. The plates were then welded to the frame. This was also done on the opposite side of the frame so it wouldn't crack either.
Another way is to grind/drill all the rivets out of the spring hanger and remove it. Then place plates on the inside and outside of the fame extending 6"-8" on either side of where the spring hanger was. Line up and drill holes in the plates to match the rivet holes in the spring hanger (maybe the body mount near there too.) Sandwich the frame with these bolts, and maybe one near each corner of the new plates, and weld them in place.
Anything you do to repair and reinforce one side I’d do to the other, even if it’s not cracked or broken yet.
Here are a few pictures of how I reinforced my frame before it was cracked. I added the gusset to the spring hanger to spread out the twisting force.
Good Luck!
Yeah. If you're going to weld around the plates completely you don't want any vertical welds. Trim the ends of the plates so that the welds won't be perpendicular to the frame. Like - <>
Oh, you too? :frown:
look at this thread and the link in it https://forum.ih8mud.com/showthread.php?t=75214&highlight=frame for ideas what to do.
There is a guy in Baton Rouge who sells the frame boxing kit that Kevin (Tools-R-Us) used on my truck. But the gussets are Kevin's design (you may PM him for more info, he did a great job, can't thank him enough). The truck now is better than new :D
Someone posted the FSM frame repair pages here, do a search at least a year back.
well thanks for the advice guys. i looked a littel closer today and well its alot worse than i thought. as far as getting a new frame i dont have the time or the money or the patience to do that. now for a scab plate do you think 3/8" is think enough or should i get some 1/2"?
here are some pics
bottom view looking up, left is the rear.
side view looking back
well i got it done today. i fixed it with some 1/4" angle iron and then welded the spring hanger to that. i welded teh crap out of it so i hope it holds. i was wrong about breaking teh frame. it just cracked a little so i welded the crack and ground it flush.
the damage cleaned up
the fix
