Broken antenna bezel - what next?
Southern Colorado
I attempted to remove the bezel at the antenna base on my '95 so that I could replace the broken mast. Rather than unscrewing, the ring sheared off at the top of the threads, so that the rest of the die-cast bezel portion is still screwed in.
I'm about 'this close' to just gutting the entire power antenna assembly and installing a generic fixed-mast antenna. Is the only solution to just take a saw or slicing disk and start cutting away at the antenna base?
Thanks!
Ouch, that sucks. I guess it really depends on if you can source a new ring. In that case, I'd hit the threads if accessible and replace as you would have before. I avoided the entire mess by just mounting a cheap autoparts store stationary antenna.
You can unscrew the ring, but it's going to take patience, and torque. The basic idea is to cut a narrow groove that you can fit a long handled tool into. Then use that tool to unscrew the bezel. Without seeing the damage, and knowing what tools you have on hand, I can't be more specific.
Oh, and tape the fender. First.
The best tool to use to remove the bezel is a bottom bracket spanner, designed for use by bicycle mechanics. I drop by the local bike shop and have them unscrew the ring when I need to have it done; it's not worth buying the tool, because there's no other use for it (on a land cruiser).
Thanks for the suggestions - I did use a 2-pin snap-ring pliers, but the bezel must have corroded and weakened (and seized) and just snapped off. I'm repainting the front clip, so if I hack the fender, it's not the end of the world.
Not surprising, it's pot metal.
Why don't you just replace the PITA power antenna with a manual factory Toyota one? Here's a listing for one and it's only 50 bucks and you'll never have to deal with it again! The vendor is Cruiser Parts.
Genuine Toyota P/N 86300-60030
larger image
Antenna With Holder
$50.91
Antenna with holder (manual, non-powered) for 80-series vehicles.
Price shown is for a new genuine Toyota part.
(Used, refinished, rebuilt/remanufactured, and aftermarket options may also be available. If so, select below.)
Tag: antennas, antennae, Land Cruiser, Land Cruisers, LandCruiser, LandCruisers
  • Shipping Weight: 1lbs
  • Manufactured by: Genuine Toyota
Add to Cart:
Used a die grinder to grind off the plastic and free the base. The entire bezel was corroded into dust (in Colorado, no less). I cut it all out and will replace it with a generic, fixed-mast antenna.
