Brakes problem
Replaced my front brakes today along with all new wheel cylinders.
now even though we’ve bled the brakes the pedal goes right to the floor.
it appears the front and back wheels have a brake cylinder each. We bled all the brakes in the order specified.
Any tips?
Yes stock. Replaced everything exactly as it was with all new parts. Wheel cylinders all matched the position of the old ones. I’m thoroughly confused because now I can have my buddy apply the brakes and i can roll the car as if the brakes are not applied. At least I thought the back brakes should catch since I did nothing to them but bleed the backs when bleeding the system. I’m guessing there is stil some air somewhere?
Is the bleed screw on the front calipers on top? If you installed the calipers on the wrong side the bleed screws will end up on the bottom. Did you bench bleed the master cylinder?
I read so Theo
He's got drums all around. Have you adjusted them so you get the drums just shy of dragging with a screwdriver or tool?
i will redo them tomorrow and check. When I adjusted them I placed the pads just shy of the drums being able slide a small pick tool just between the drum and the pad. I did read on here that a good way is to adjust the pads until they catch the drums and won’t spin then back off 2 turns. I can try that but I didn’t think there was much play at all between the pads and the drums when I did it.
I did not bench bleed the master. Is this necessary?
Here’s my master
I should note that the brakes had good pressure before the brake job. My rear wheel cylinder in the passenger front was leaking sO the fj would pull violently to the left into the oncoming lane of traffic with brakes applied. I assumed the passenger front brakes were not engaging. Anyway I think I can figure it out tomorrow but wanted any tips that may be helpful. Thanks
I would jack up each wheel and spin it while adjusting the adjuster until you feel it drag. That should get your pedal situation a little better otherwise I'd say you still have some air in there.
Thanks. Maybe I am missing something here. On my 63 bug I can adjust the pads through the drum. It sounds like the way your are describing it that I can adjust the pads while the drum is on. The only way I could see to do it and how I was doing it was to keep taking the drum off while spinning each wheel cylinder up notches and the putting the drum back on then repeating that over and over until I got the pad close to the drum.
Not correct on bleeding the master. If there was any opportunity for air to get in the system then you should always start at the beginning, the master, and work to the end. Air moves.
This makes sense. I don’t understand how I lost the back brakes too because I didn’t do anything with the back brakes. This is why air in the master seems to make sense to me. Big again it appears that the front and back brake lines ate separate closed systems with 2 different reservoirs. How can messing with the front system affect the rear brakes?
The best way to adjust shoe brakes is on a lift. The next best is to get one end of the vehicle raised getting both wheels off the ground front or back at the same time, so you can balance the right and left adjustment so they feel the same. This way will make it less likely for one wheel to grab more than the other.
If the reservoirs on the MC drained out while you had the slaves off then you might have to bleed it.
Sounds like there is still air in the system.
Good god. Does anyone here know if the wheel cylinder notches raise the pad by turning them clockwise? I’ve tried both counter clockwise and clockwise and haven’t hit the drum with the pad yet. I’ll figure it out but I don’t feel like taking the wheel hub off again to check. Spinning them from underneath isn’t bad but if anyone can help at least I’ll know if I am spinning the notched wheel on the wheel cylinder the right direction. Thanks.
