Brakes problem
Btw here’s my ride
Well I answered my own question but this thread might help others. It is counter clockwise to raise the pad. Finally hit it. Counterclockwise Raises the wheel cylinder piston
OK so then another question. I read on here you spin the wheel cylinder until you can’t spin the tire then you back off two notches. But if I do that there will still be rubbing of the brake pad on the drum is this what I want to do?
Awesome! What Manual is that please. Although I have had two newer series landcruisers this is my first fj. Big help. Thanks!
So I was partially incorrect. Funny the engineers would make the wheel cylinder adjusters different on each side. I’ve read that to tighten you turn away from the axle and I didn’t know what that meant. So basically to help anyone else doing this it hasn’t done it before when you have your screwdriver in the adjusting slot and your butt end of the screw driver is parallel with the axle move your butt and away from the axle and this will tighten the brake pads. Or you can think of it as driver side clockwise to tighten, passenger side counter clockwise to tighten. Does anyone with more experience have anything to add does this sound correct because it worked for me.
If you do not have that Toyota wheel cylinder adjusting tool a small flat head screwdriver works just fine medium length except for the drivers front wheel cylinder because the shock gets in the way from being able to move your screwdriver I’m gonna have to run to the hardware store to get a shorter screwdriver or come up with some other answer
I believe all adjustments to tighten the brakes,is to move the adjuster handle away from the axle tube.
I might order one of these:
Yeah. Wish I had one of those right now lol. I’m going to bend a screw driver and see if I can access the last slot. What a pain in the ass. And I’ve done my fair share of brakes. The only 2 things easing my pain is wondering how much a shop would charge to do this and also the sweet smell of victory when I am done.
Works perfectly! By the way I tried a block of wood on the ground and pounded the screwdriver with a hammer but that didn’t work. So I just stuck it here in the fj and pushed down to bend it. Worked Perfect
Check out what happened to my harbor freight vacuum pump on the second wheel bleed. Lucky I had googles on. Brake fluid all over my face as it flew out of the gauge!
So I posted some of my most frustrating steps to the brake adjust. Hope it helps someone else.
@Slik The rest of us neophytes appreciate and applaud your efforts. MUD salute to you sir :flipoff2: (<--meant as term of endearment)
I have front brakes that pull a bit left when I step on them hard. I will be adjusting mine when the weather warms a bit. Currently a balmy 20*f... Looking like this weekend or next spring...
That's correct. Here's a diagram of sorts A stupid question about rear drum brake cylinders
thanks! Good luck.
Was replacing the wheel cylinders on the back. The rear wheel cylinder of the rear wheels have brass tabs that contract the wheel that you spin to adjust the brake shoes. Unlike the other wheel cylinders that have a thin steel tab. I just broke both brass tabs off the brand new rear wheel cylinders simply by rotating the adjuster. Wtf did I just do wrong?
