Brake tech, 96
Sacramento Ca
Been reading, common upgrades of slotted/drilled rotors, green pads, which I'm considering, already did slee 6" kit and 37s, brakes are middle of the road. I have two questions and input from others would help. I come from the mini truck world, with my latest prior to this being an 84 xcab. I had 38.5s on it, with drilled ifs rotors, factory pads and it didn't stop. I removed the lspv rod, from the valve to the axle, and made a bracket to hold the valve in the stock position permanently, and they worked almost where I wanted them. Then I read about upgrading to an 80 series MC, which I did, and after dialing it in, I had to back off the lspv a bit due to rear locking under hard braking. Bam, it was perfect. My two questions are, I have medium weight rear springs and don't plan on any loads or trailering, just a bit of camping gear here n there, can I do the same to the lspv with the 80 (based in what I see, looks like the same setup)? Question 2, is there an upgraded MC for the 80? Sequia, T100, Tundra? My xcab would/did a nose wheelie once hitting the brakes downhill, and id love the same performance. I do realize the 80 weighs almost twice as much, but if the wife is gonna drive it with the baby, I want it to stop darn well. It drives straight and handles well, the alignment guy was pretty impressed with the caster built into the arms and the numbers showed it, but stopping is sub par. Any .02 would help in figuring this out. Oh yeah, new booster replaced end of last month as well, and the pads are at 7mm F / 6mm rear currently. Been looking around and no one has seemed to have gotten too far into swapping MC's.
I wouldnt feel that the stock suspension angles with a 6" lift and 37s are safe for my wife to drive with my kids regularly. Can you have her use a different vehicle?
Ha-ha, she normally drives a kia soul! Just a once in a while thing with her driving it, and she's mentioned the difference in braking a few times since the lift and tires went on. For me its a little sub par, but there's that whole "happy wife happy life" thing that keeps the machine well oiled. If she's cool with it then there's no worries. I think first I'm going to address the lspv, as that was the biggest difference in the past. Went from mediocre to pretty darn good in about 20min
Yeah, a Kia Soul is a skateboard comparatively....bu you already know that! A 3500 Lb vehicle will stop considerably different than a 6" lifted 6500 lb truck!
There is talk about brake upgrades, but nothing that has come to fruition that I have seen. Definitely nothing bolt-on. Anything that someone has done has probably been one-off and they haven't published it.
Hard to do a nose wheelie in an 80 series due to the design of the radius arms. When you hit the brakes the arms lift the front of the rig giving you a false sense of poor braking. Rear control arms kinda do them opposite. Rear axle pulls down on rig, results in very flat braking characteristics that mimic poor brakes. Some folks don't understand how this works. John
Thanks John, I'm fully aware of the characteristics of an 80, I was just using the extreme braking of my last p/u as an example. And at close to double the weight it will never stop like my old rig. The main point if the thread is to find out what folks have done to upgrade the MC in particular. @BILT4ME has it right, likely a one-off deal and no one has nailed it down to have a definitive answer. Just curious to know who's tried what, what works, what's a no-no to avoid, and so forth.
About as creative as anyone has been here is to install 100 pads in the front of an 80. Then everyone goes back and forth about slotted and drilled vs OEM plain rotors.
@scottryana has hinted toward coming up with some much heavier brakes for his upcoming build, so we can watch what he's doing. Thus far, not much because I think when the guys are going that heavy they have upgraded to one tons and bring the brakes along.
We'll keep watching!
Ok. What works well for me is basically all stock parts other than EBC pads all around. On a secondary street @ 45 mph , I can nail the pedal and all I can hear is rubber ripping at the asphalt. The ABS will not let it lock up and there is no hints of the ass end trying to swap ends. Nose does dip a few inches, but nothing like a leaf spring rig. I really don't see a way to make it stop any shorter. I think the ABS is probably working somewhere between 90-99% of locking up, which of course means it would stop longer .
I currently have my ABS disabled and I am running Duratracs 285/75/16. I can lock up all 4 from 50 MPH without a problem. The rear tends to swing out a little, so I have some adjustments to make to the LSPV. Been chasing a "which wheel is going to lock first" issue that seems to want to eat pads in the RR. Replaced the hoses, caliper, pads and the issue continues. Looking for smashed brake lines this weekend (due to PO)
You obviously had to go with longer brake lines. Has the ABS been engaged since you flushed the brake lines? I saw a thread recently were some folks realized they had trapped bubbles that they couldn't remove until the ABS was activated.
The brakes have been bled twice since the lift. First time the old fashioned way and second was a power flush. I'm 200% confident there's not a lick of air in there. It almost feels like the brakes are wet. I've gone as far as taking it all back apart just prior to the power flush and making sure, the rotors are not glazed over and I even scuffed them with a roloc disc and cleaned the pads with brakleen. Having a 15yr background as a mechanic, I know where to look and what to do to get things dialed in, and now I'm to the point of I'm going to mess with the lspv, and after that I'm thinking of clamping force on the rotors and is it up to par. You guys are describing lockup is fairly easy, so I'm gonna have to chew the fat and find what the problem is
Phildoh, did you ever get your brake issues resolved? I have a similar problem with my 95 but it only happens with the first few stops after initial startup when the brakes are cold. It feels like the brakes are wet and I have to really mash the pedal to get the truck to stop. I am installed Akebono pads 100 series pads and let me be the first to say that they were fantastic on my 2002 Maxima but AWFUL on the LandCruiser. Initial bite is almost non-existent and they require more foot pressure to stop. The original 80 pads had great bite and stopping power.
BTW, I found this thread by searching for replacement rotors and pads. I will be replacing the Akebono pads with EBC green stuffs. I haven't figured out the rotor options yet.
Rotors- Brembo blanks.
Pads- Porterfield R4S pads.
That setup has been autocross and trackday proven in countless cars for decades, and will change how you feel about OEM- sized brakes. ;)
Can't do any "blanks" as the rotor is an integral part of the hub assembly without having custom machined hats made to float rotors onto. But yes has been looked into....
Oh those are just OEM replacements. They are stock size. I thought you meant a meaningful increase in rotor size by using a blank 2 piece rotor. Yes you can bolt any OEM replacement rotor you want on.
H_Y_D_R_O assist out of a 1 ton late model chevy. Nearly a bolt in affair and nearly twice the assist. No need to go crazy expensive custom crap. 200$ and you can get the hydro booster and master cylinder from a real truck. It also helps clear big shock towers if you need to.
Blanks have been the term I've seen used and have used myself for about 20 years in reference to those OEM sized rotors. I apologize for the nomenclature confusion. :) Semantics aside, they will last the life of the truck, won't warp, and combined with those R4S pads, will provide phenomenal braking. I did about 60k miles on that setup in a '92 Celica AllTrac between canyons, autox and open track days, and when I finally swapped them out for some 13" Wilwood rotors and six piston calipers, the R4S pads had about 60% left and the Brembo rotors were just barely starting to develop a ridge on the outer lip.
