Brake piston help?
Texas
So in replacing my front axles with RCV 30-30-30's cause I snapped a birf, I decided to do the only prudent thing and slip in some 100 series front pads.
WELL I have a piston that is hanging up about 1/32"? from going all the way back to a retracted state, and the pad WILL NOT fit. I have tried a C Clamp, pry bar, Cracking the bleeder whilst doing these, and its just hanging up enough to not let both pads in with the rotor.
Is there a way I am not thinking of, short of rebuilding the caliper, to get the piston to move the last little bit in?
If you are using after market pads you have to pry the squeal pad off of them so that they will fit.
1418244548285-jpg.1003857
1418244571438-jpg.1003858
Using OE toyota pads from a '99. Or thats what I thought I ordered from TPD? need to double check the PN. Maybe I should get some EBC'S probably would of been cheaper!
I have heard that 100 series pads are a tight fit and removing the squeal pad helps with fitment. I went with EBC and the bite of these pads are fantastic compared to the OE pads. I was able to fit the EBC pads with the squeal pads in place.
