- Joined
- Jul 22, 2012
- Threads
- 639
- Messages
- 17,558
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
that'll do it
That was my first consideration, but I've never had rodent problems beyond squirrels digging in my lawn, plus the loom and tape around the break weren't chewed up at all. It had to have gotten tweaked at some point or something. Either way, it's gettin fixed this weekend.i will say MICE chewed those leeds on you Dan for sure ............
that Darn TOYOTA JIS MOUSE strikes again !
Spook...this could have gone a different way with a lesser man. Under other circumstances your 60 could have been parked in the back of an overgrown yard with raccoons living below the seats and rust eating away the remaining metal. Another survivor.
I kinda wonder if it got nicked when the fuel tank recall was done 30+ years ago (if it actually was done, which I'm still not 100% sure of).My guess is someone accidentally nicked it at some point. This allowed for corrosion to start from some salty roads it was driven on and if it's in the harness it didn't properly dry out. Then as more and more green corrosion happened there was less sound metal to pass the current until it started to heat up and melt a little bit then finally break.
Cheers.
I'm honestly curious too. I didn't think to do it while it was apart, but one day in the future I'm going to take a reading of just how much current the fuel pump pulls.I wouldn't be surprised if it runs noticeably better all the time now, Fuel pump voltage is important
I completely redid the same harness in order to get the fuel sender working properly. Glad you found the issue.Okay NOW this story has officially ended! I decided to put together an entire new sub harness from the quarter panel to the fuel pump and sender. Used my 16 AWG silicon insulated wire (given the choice, I would've used 18 AWG for the sender, but I don't have any so really no big deal), a few Weather Pack connectors, and I was able to reuse the factory sender connector with new terminals.
I got curious to see just how far along the corrosion went before hucking the old harness in the trash. The only clean strands were the bit over a quarter inch on the end of the harness inside the quarter panel, but aside from that the ENTIRE length of the fuel pump hot wire was black and green! How it managed to support the current draw of the pump for as long as it did blows my mind.
So I got to work building the new sub harness. Started from the 4-terminal connection in the quarter panel and went from there. Given the wire coloring available to me I substituted the brown wire for blue. But I never plan on selling the truck so that's an easy one for me to keep track of.
The part that'll be inside the truck body I just used some spiral loom for. I cleaned up and was able to reuse the factory grommet, which was nice. Pro tip: Astroglide works magic for feeding wires through conduit and slightly-too-small grommets without tearing things up..........so to speak.
The "exterior" portion is in new nylon split loom. The piece of shrink wrap wasn't critical. Just put in place to prevent the electrical tape from coming undone over time.
Daddy don't play. Every terminal I install on any wire is crimped properly and then soldered. I'm a HUGE fan of the silicon insulated wire because it'll handle the heat from soldering without deforming or separating from the conductor at all.
In the truck I replaced the factory connector with a mated 4-terminal Weather Pack, installed the "vehicle end" of the new harness, and then after fishing it into place (without dropping the tank, which was nice) I finished building it in place. No pics of the pump and sender end of the Harness since there really isn't anything special to see. In the pic you can see I put a small length of shrink wrap on both of the 20 AWG factory leads for the fuel gauge & sender. This was to provide a small degree of strain relief for this (IMO) way too small wire.
