Great build, good read and miss those days with my kids, they have to grow up eventually...
Rob
Rob
It's mostly cut pieces. There is one sheet for the top surface, a piece for each end and the sides are each one bent piece. I don't have a press brake so I used the "whiskey bend" method but cutting about halfway through the sheet with a cutoff wheel along the line of the bend, then bent it and rewelded the surface.Did someone bend that lid for you or did you weld pieces together? I dig it!!!
Those were intended to be used more as "camp lights" rather than reverse lights. Also the ones in the photo you saw where far to big for that use, but it's what I had at the time I was working on a way to make them work. I now have a pair of small dual row 6" LEDs that will be used there.Great looking and functional trailer.
Got a question for you if you don't mind.
In another picture I found of your trailer I noticed two back up lights.
Were they used for backing up?
Camp setup?
Just having a hell of a time figuring out how you would turn them on from inside your truck when backing up.
If you were able to turn the lights on from inside your truck could you explain how you did it?
Have a good one
Yes, the contraption is a simple stabilizer. Inexpensive and effective. Has worked great for me, packs up pretty small and makes for nothing hanging down under the back of the trailer.Hi Adam,
Absolutely love your trailer. It is my source of inspiration to build one of my own and when I do so will definitely be gratuitously ripping off some of your design ideas, most notably the telescoping tent rack which you've since moved on from.
What's that contraption you've got supporting the back of your trailer in the first picture of post #226? Is it some sort of stabilizer? I've never seen one of those before.
Bought it at Camping World for like $20Did you fab it yourself or buy it somewhere?
Thanks for the compliments! The reason I post stuff is in hopes that it helps someone else and give ideas about what can be done. That’s why I’m on forums like this and I’ve stolen ideas from others so many times so it’s an effort to reciprocate a little. It’s nice to hear when someone gets some inspiration from something I’ve shared. So thanks.I love your build (except for that Y sticker on the corner). I have a HF trailer that I modded down to 4'x4' (ala Dinoot) and slapped on some wheels and tires to match my '08 4Runner. It's a flatbed right now but I have been planning for some time to enclose it. I will more or less follow your build as you have most everything I want in a trailer and some things I hadn't considered. I plan on using it mostly to haul gear camping and load bikes on. Thank you so much for the invaluable input and suggestions. I've got my order from Wasatch Steel ready to go.
A couple questions I didn't see addressed in the post, what gas strut did you end up using on your lid? Where did you get it? Does the lid seal ok? I'd like to keep the Uinta Mountain moon dust out of my gear.
Now that you have had this thing for 10+ years, is there anything you would do differently?
Thanks again for this awesome build!
