Build Bonnie '62 FST in WA
Pondering what the split windshield would look like, but this doesn't really help.
All righty then. Clemson Cruiser put one on an early rig and everything fits perfect save the inside windshield latches. The bottom of the earlier windshield is thicker to accommodate the early big air vent. The split screen's lost real estate doesn't allow the clean use of the early taller latch.
What does the vehicle body side look like for the latch of a split screen windshield?
This is the green split screen windshield side. If I use Bonnie's latch the top triangular piece is a bit too tall for the windshield.
Bonnie's existing white 1962 latches:
I think @whitey45 used an '81 era black knob arrangement. Not sure what that looks like.
For my ‘63 FJ45 I was going to have to make something to combine the 2 different bracket sides.
@HelloKitty65 be aware there are 2 versions of the Safari windshield. An early version and the later model version that I have.
OK. This thing has been on every FJ40 since 1968 and I didn't know it existed.
SOR says a cover was also used on non-US trucks without dash pads, but it's discontinued. :(
@FJ40 MATT had some and if I'm lucky maybe zero new holes will be needed.
Got one of Chase et al's (@red66toy's) plates (from Mark's design) to adapt a four speed transmission to column shift. Not having the originally numbered engine seems to free me a bit, and I do have a four speed transmission sitting around. Wish me luck, when I get around to it...
Thread 'tranny tech 403-thats 4 on the tree!' tranny tech 403-thats 4 on the tree! - https://forum.ih8mud.com/threads/tranny-tech-403-thats-4-on-the-tree.134392/
(@red66toy's pic)
Seeing what a higher clearance four speed transmission tunnel looks like for the 4 on the tree idea.
Got some big holes to fill.
A little test fit. The wiring harness holes in the windshield and the body don't line up, but otherwise it works. Wiper motor holes are in the correct place for an early windshield
I hope that every departure from stock is reversible for a future purist owner. Good parts are hard to find.
So I spotted this potential source for some _ribbed floor boards_. Apparently they were recycled into a government contract, there are 6 sets of them, and they have been kept in a totally rust free environment for up to the last 57 years. Perhaps with some MUD ship specific help by a cruiserhead/aviation type who is headed that way (to the moon) again in little while? They may have suffered from a high fall but it would have been at 1/6th the earths gravity and they may have landed onto a powdery substrate ( or not).
Some might consider this piracy, but clearly these LEM parts have been abandoned and there is no LE or court jurisdiction to interfere with the lunar moral high ground of this salvage undertaking.
Getting closer on this and the soft doors. I'm going to miss the old stencils.
Plans change. Might again transmission wise. Pondered what this ball of grease and dirt was sitting on a shelf.
Started picking at it. Under it all, the proper for this truck, 1962-1963? side shift 3 speed and transfer case.
Still learning.
I hope I have the parts to connect it to the tree. I found my parts catalog incredibly vague on what that takes, but do have more unidentified bits.
Still learning.View attachment 4155566I hope I have the parts to connect it to the tree. I found my parts catalog incredibly vague on what that takes, but do have more unidentified bits.
These were used 61 to some time in 63. My 63 FSM has a separate FSM from 63 for common three speed transmission and transfer case use in some markets well past when the H41 and H42 started. Looks like the arms for the side shifters are still there. That's a plus.
