More info?
that isn’t the turbo housing blanket is it?
no its the phallus of the WasteGate
More info?
Add me to the list.no its the phallus of the WasteGate
@NLXTACY are your banana hammocks for sale? I searched for "banana" and "blanket" and looked through the entire turbo/supercharger section, but i didn't see it.
I only have the one “gently used” one. Others incoming
That is really clean. Thankfully, I did not cut that bracket off when it started to get i the way. Almost took the dremel to it a few weeks back. Looking forward to this kit.On the methanol kit, I've got everything worked out but its not quite production ready because its not as bolt-on as I'd like it to be yet. Here is a simple mounting bracket solution for the boost switch. Its a simple hobb's switch. Its adjustable but I'll be setting them all here before they go out. Switch is normally off and once boost hits 2psi it connects to ground which turns on the pump. Let off the gas pedal and the throttle plate closes so no boost so the switch disconnects ground. Its crazy simple.
The issue was just about the mounting of the switch. A simple mount was made and it secures the switch to the unused bracket off the MAF. Works perfectly. I'll be making up a batch of these to go with the eventually kit.
View attachment 2417305View attachment 2417308View attachment 2417309
View attachment 2417311View attachment 2417312
Not etched, scratched in with a screw driver...I'm envisioning a clamp onto the neck of the air cleaner with a pig's ear for bolting this on, and the name of my new company etched into the black anodizing "Witty Ends".![]()
While waiting on a Banana Hammock I thought I’d post a photo of a non-traditional install (in-progress) of the @NLXTACY turbo kit.
Proving it’s possible to turbo the 3FE If you try hard enough.
looks awesomeWhile waiting on a Banana Hammock I thought I’d post a photo of a non-traditional install (in-progress) of the @NLXTACY turbo kit.
Any update on current status....group number, next expected shipment etc?
so we should order en-masse?The batch after these will get me all caught up and frankly I can't wait to be done with these stupid things.
