35s + stock gears + no turbo = not ideal.
35s + stock gears + turbo = Ideal for highway and overlanding
37s + stock gears + turbo = badass!
FIXED IT for you!
Gorgeous truck. Just ordered my suspension - 3" icon with DVS helper kit. Having a tough time deciding between 4.88s in the diffs and high range t-case gears for 35s.
Great info, thanks for sharing. Diff gears are where I have been leaning as I like the feeling of being slightly over-geared.I have the t-case gears. I wish I had went with 4.88s for 2 reasons and probably will switch back to stock gears and get 4.88s or 5.29s.
First and foremost - the high range gears definitely make noise and it bugs me at 30+ mph and especially on the freeway. I have KO2 ATs. If you have mud tires and don’t mind the noise on the highway, the gears probably won’t bother you.
Second - the 1.1 honestly isn’t noticeable while driving. I have 2 80s, one with 1.1 and other with stock gears, both on 33-34” tires. I can’t “feel” a difference between them driving but I certainly hear a difference. (I live in mountain valley at 4500 feet elevation with frequent climbs over mountain passes, at sea level it’s different.)
I love the 3.1 low range gears, they are definitely worth it. I am going to put the turbo on and see how things feel and sound, but right now I plan on yanking the 1.1 gears and changing axle gears.
Wow I've heard that the TC gears made a little noise but I didn't think it was that bad. I've also heard axle gears make noise but I've noticed no difference between stock and 4.88's. BTW, I absolutely love 4.88 gears for everything from city/highway to offroad. The higher RPM band makes driving feel effortless.I have the t-case gears. I wish I had went with 4.88s for 2 reasons and probably will switch back to stock gears and get 4.88s or 5.29s.
Just got the call from SEMA. I made a point to NOT discuss the “incident”. This truck will be going in next week to be baselined and I will doing the mileage accumulation myself.
Also, I’m heading to the pipe shop in the morning to go over the jigs before cutting/welding starts.
So, they're not going to let Super Dave drive it this time?![]()
I’ve dialed back the design of the turbo kit. Turns out all I really needed was this. VROOM!!
View attachment 1985047View attachment 1985048
The issue isn’t these, it’s the turbos. But looks like first units should be ready in under a month.
Any idea on Rough ETA of the carb process? Granted I won’t be able to do anything well into July.
zero unfortunately
