Careful! The price just went up!
It’s about to!!
What size pulley was on the SC truck? and any info on EGT's?
I kind of have to disagree with that statement. The intake air temp will change depending on how hard the turbo is working to compress the air. The more air its compressing-ie up a steep mountain pass, the more heat is created. Especially after heat soak happens the IAT will be much hotter going straight into the engine. An intercooler would help cool the air back down and make it more dense before entering the engine, hence more power. Who knows how much, but I think it would be measurable by the end user with a "seat of the pants" dyno.The intake air temps on 3 back to back pulls did not change the HP/Torque numbers. The only time you are going to see higher numbers with an intercooler is when the temps are hot. So they wouldn't change in this situation, if it is 105 degree summer day you likely won't see these numbers and an intercooler at that point would get you back closer to them.
So, at my elevation of 7,000', using 3% power loss per 1000' = 21% loss. So that equates to 25 hp loss at elevation, which means I'm using up a whopping 96 hp to move my 7k phat arse around.![]()
I believe that 3% is based on naturally aspirated gas engines. With a turbo the loss is much lower.
Nice. That will be a great power increase over stock. Nice to see legit numbers and time taken to get them. Only bad thing is that now were going to see lots of 80s pulled over on the side of the road...getting speeding tickets.
Okay, I'll take your word for it. Care to explain? Lost me at the end of that.Go ahead and disagree with it. What I said is correct. In most driving situations you will not make more power than what was put down today with an intercooler. You will loose power when it gets hot and you will get closer to the power figures listed with one.
Oh my bad I see what you were saying.That is correct and that is why I made my statement. I have a NA vehicle.
Agreed. I guess I didn't read exactly what you were saying. I was referring to the average user here under what could be considered a normal drive, not the dyno. All I was saying is that if you want to feel like you have the same power when you leave your house and get on the highway as you do when you've been in boost for 10 minutes straight going up a steep highway you would benefit from an intercooler.An intercooler does not make power, all it does is restore power lost. You will not make more power by adding an intercooler. The highest amount of power you will make with this kit, give or take is 220awhp and 274ft/lbs all wheel torque. Yes you can lose power when the temps are hot and yes you can get close to getting that loss back by cooling the air charge but you will not make more power over cool temps just by adding an intercooler.
That is something Joey will have to work on. I have screenshots of pictures of the pulls, but nothing that is very good. I guess they told Joey they would get him data so he could have good visuals, but I know sometimes shops just want you to get your 3 pulls and move on.
Like this is the first pull SC vs Stock, but the max power number wasn't right because the trans shifted right at the end of the run that I cut off.
He's busyJoey is a genius and a Master
Congrats on this superlative performance.
You deserve this news Joey for your Edison like persistence.
When the hell is my blue fan clutch getting shipped?
Videos!
I wanna hear ‘em !
Just watched them. Like music to my ears. Not the sc, the turbo.I’m uploading on YT so it can play nice on mud![]()
