Body mount position 1 Solved!
Currently Silver City New Mexico
I would love to hear how you got this beeyotch!
Read everything i could find in the forums and YouTube but i am stuck. Broke the bolt, drilled drilled drilled... but that damn bolt sticks up into a recess so it appears i have to cut it from the top - man that is a tough spot!!
My best guess at this point is to pull the running board off to try and get a recut saw in there?? I'll have to bend a blade with 2 90' angles.
I have already winnowed out those bolt holes fighting to get a drill in there.
Hacksaw and filed the bolt up to the top mount...
If i could get that flat metal away from the bolt??? Is burly metal-can maybe drill a bunch small holes around bolt capture part?????
yep. hardened steel. why don't you just take all the body mounts out and lift the tub a few inches? The only hard line that
probably doesn't have enough slack is the brake lines coming up from the frame. Those can just be undone as well
as loosening the bolts on the front fender to frame attachments.
Dremmel with small cut off wheel and grinding stone, work that tip of bolt down until the whole mess can slide out. i would speed it up and use the 4" grinder with an old cut off wheel thats been widdled down and just grind off most of it then dremmel, you might mar up the edges of hole a tad but it will take like 5 min.
Thanks for taking the time. I have all body mounts loose or cut. Lifted body up 3" doesn't give me any better access. Fenders loose. Hitting steering column at high point.
I have to lower body to reach with drill. Can't drill anymore.
There is a full inch of bolt still above the top of the old mount above the body mount attachment point that you see in the pic...
Not sure how to get adremel in there if i go buy one either.
Thanks for the reply. I may have to go buy a dremel tool.
I do have a roto zip but not sure how to use it here.
If i can destroy the flat metal part of the old mount, i may be able to get bolt out.
Still a lot of bolt above that top mount point.
Brake lines okay with lots of coil and new extended soft lines. 👍
Been there, man. I ended up cutting away as much of the old bolt as I could, and then used a long rod - I think it was a super long socket extension - and a BFH to drive it out the side. Good luck, and may the force be with you.
... and also with you. I had no idea that this was a possibility after scouring all resources. Looks like the other side will come out. i hope.
