Dealer would just swap in a new OEM long block and scarp the engine. They'd also swap radiator and many other rubber and plastic parts out for new. Ton of labor involved. So pricy rout to take.
I would agree that timing belt rarely if ever takes out a 2UZ-fe maybe not even the VVT-i. But coolant system is the achilles heal of or 100 series. Tees being the biggest concern but proper maintenance of coolant system and inspecting level frequently is very very import. It is more import than oil changes IMHO.
It was report to me; "as soon as something was wrong (Dash lights and running very bad) it was shut down and towed".
Indication are it was run hot for some time, possibly hundreds or thousand of miles. I say this because of color of some part and radiator neck cracked. It's possible coolant was low for a year ~20K miles, that was last flush. I've seen my share of low coolant systems, with gauge reading low falsely. Clue something is wrong is when cabin heat is turn on and it blows warm or cool, as it should always blow very hot when turned to hot. But I can imagine cabin heat is not used much in the South, and goes unnoticed..
Or could be Tee just started leaking, and once level low enough systems cascaded.
Stay tuned I'll start a thread on The Unicorn soon.
First from what I've learned, cost to have a Toyota Dealer do this job is in the $12 to $14K range. JDM for the 2UZ-fe VVTi Land Cruiser are not available from any sources I've found. If someone has a source I'd be interested in hearing about it?
IMHO this was not neglected by PO. He's not a mechanic or DIYer, he relied on Toyota Dealer to maintain. The Toyota History on this one was good, better than most I look at. I'd would not have been concerned with a 10 year old with 127K having a heater Tee failure either.
Other than the blown engine this Unicorn is very clean and was well taken care of. I suppose because it is a Unicorn, PO's respected that. It's not only a Unicorn but and 2007 Unicorn. It is one of the rarest 100 series in the lower 48 of the USA. It so cool it just ended up in my garage.
Funny thing is, I didn't realise it was a Unicorn, and The Unicorn I'd been pining for until after I made the deal, and had here a month. I was just in for the Challenge present by blown engine.
