Blown Headgasket
Broski
I love Wheelin my 80
At the edge of the Pacific ocean
Hi I just bought a 1994 FZJ80 with the factory lockers. It has 270k miles, CA car, no rust, all stock. My plan was to build a trail rig. Thing is, after I got it home, I figured out that it has a blown head gasket. It runs really good, has good power, past CA smog, the only symptom is that it builds pressure in the radiator.
I was thinking about doing the head gasket, just decking the head, putting a new timing chain on, and running it.
This is my first Toyota, and from what I heard, these cruisers are really over built. I want to get this thing dependable and I am not sure if starting with 270K mile rig is a good idea.
If any of you Toyota guys want to help me out. please give me your opinions
All engines develop pressure in the radiator as the engine heats up. Can you explain further what you mean.
Depends what you paid.
IT has a new radiator in it. it developed enough pressure to make the lower tank leak. I took it to the shop and they ran a test and confirmed exhaust gas in the coolant.
Make sure it isn't just something simple and not the head gasket, but if it is, it's a bit of labor and some $ but you can do it. 270k is nothing to the engine if its had remotely regular maintenance so I wouldn't worry there and you shouldn't need a timing chain, just the gasket kit (which is now the complete engine kit), thermostat, and EVERY heater hose. Great way to get experience with your new 80. Read up on the head gasket write ups here in MUD. Have fun
I agree with dogfish you will learn so much about your rig download the fsm on here to.I bought mine knowing it had a problem with head gasket.fixed that and did some while your in there stuff to it and I drive it every day with a smile on my face knowing I did the work and done it right.now on to cosmetic stuff as I've driven it long enough to feel confident about it's mechanical workings.sliders next and tube bumpers etc
Congrats on your new Cruiser, you'll love it. Bummer to hear you probably need a head gasket. There's a lot of knowledgeable Mudders on this forum that will be willing to share their experience with you. Changing the head gasket is a pretty labor intensive job, but not that difficult. Wishing you the best with your new ride.
Thanks all got to go to work check back later
With all due respect to Pin Head, my opinion: do a HG job, and do it yourself. Check my posts on the subject forma couple years ago, which will include costs using OEM parts. While my engine is only at 190K, I did just get a Blackstone oil analysis report back two days ago on my engine, and it was very reassuring; one comment on the report was "Wear looks great." Blackstone is a great resource too, if you want another opinion on your engine's wear and coolant/HG situation.
Most every person on MUD I have read about that decided to tear down the whole engine instead of just the HG found very little wear on the bottom end. If you still have clean oil (no water mixed in from the gasket failure), I'd totally go for just the head gasket. I suppose if you pulled the head and found major issues on the cylinder walls, you might go to plan B then, but I bet you will find perfect, clean cross hatch. A full rebuild is totally cool and kudos to those that have tackled it, I just don't think you will HAVE to.
Strange that it developed enough pressure to cause the lower tank to leak. The radiator cap is designed to keep the pressure limited to 16 psi. You should of seen coolant puking out of the overflow bottle.
Some good advice and a couple different paths to go down based on budget, time and experience. Is your coolant milky? does your exhaust smell like coolant? Is the truck drinking coolant, so you have to fill it up every few days/week? do you trust the shop that tested it? some questions to answer, though you may not know all of them now.
You live In calif there are many knowledgable Mudders close to you that would most likely be willing to take a look at your Rig. A hands on view of your situation Is the best thing. I am not sure but some Calif. Mudders dont seem to realise the value of a rust free vehicle. Its huge, there are so many things ruined just because of salt. If your H/G Is blown I would rebuild, at the price you paid for a locked rust free 80, plus the rebuild you would be less than the average similar 80s here In the midwest Is selling for and you have a rust free rig. Most locked 80s In chicago area 93 to 97 are around 7K with 200K plus mi. An experienced 80 man could tell If Its clean enough to be worth the bill. Your experience would be Priceless...! LOL Best of luck.. :) BTW, Don't feel bad you are the 6th man this year on mud I have read of that arrived home, or close to It with a blowm H/G after purchase, I may have missed a couple to. :cheers:
With all due respect, pistons rings and bearings wear and replacing them with the engine out is not that expensive and not that big of a deal. Why go to all that trouble on a tired engine when you can do the whole enchilada for a few $$ more. Toyota says that the 1FZ has a wear limit of 300,000 miles for a reason.
Interesting about the 300,000 wear limit, never knew they listed one.
The FSM reccomends a rebuild every 200K and an engine life of 600 thousand If you do so.
My vote if for Bars and roll the dice. While you are driving it try to find a used motor to rebuild on a stand and if your current motor goes or you have the time swap them out and repeat.
And since I'm a 3FE guy I will just say it... Shoulda bought a 3FE!
Ok it"s not my DD and I have only driven it about 50 miles. The oil is clean, the over flow tank has clean coolant in it, the lower tank has clean water coming from it. It only happens after it is warmed up and driven a bit. The water is what tipped me off of a bigger problem than just the radiator.
The shop that I took it to performed a chemical test for a blown head gasket. It was a Saturday and they let me hang out and watch. The tests were positive and I have the samples.
The previous owner stated that the Cruiser did not over heat when asked. Of course his wife drove it.
