Blown Headgasket
I think you came up with answer that works for you in the first paragraph of your first post.
However you may consider: Compression test? Spark plug inspection reveals what? Got engine leaks that would be easier to correct with engine removed? Budget? How heavily will you depend on this vehicle in the future? Lots of miles or mostly trail use? How long do you plan to keep it? Can you do all the work yourself or are you at the mercy of a shop? Have you any knowledge of its maintenance history???
It is mostly going to be a trail rig and with all the good info that I've gotten from this post I am leaning towards the head gasket. Definitely don't want to put any head gasket sealer in there; if I didn't do the head gasket, I would go the full rebuild route. was looking to get it dependable then build it out similar to a baldilocks' rig.
Does it have good oil pressure? Once head is off you can see cylinders- may still have good crosshatching. If not-
Search for basic rebuilds on here with just rings/bearings/gaskets/etc. done along with HG.
Why?
You would prefer it to leak and maybe overheat and F something up big time while you are figuring out what to do with it or is the $20 too much money?
The Cruiser is not being driven until the problem is corrected as I have several other vehicles to drive. It was purchased with the intention of building a street legal dedicated trail rig. Thanks
Hi guy's Thought I would give a update.It at a shop I like the mechanic he drives a Toyota and works on them. The head is off and he called to have me come take a look. I'm very happy, The mechanic first words were some one took good care of this. There is no visible wear on the cylinder walls,.the head & valves look good in short he said everything looks good he even side all electronical connection we good ( no broken clips) & no stripped hardware like a lot of older regs he works on
Good for you man! Do you plan to go any further than HG while it's open. Bearings would not be a bad idea at all. And speaking from the standpoint of someone who has an engine on a stand as we speak to get it ready for Spring, it is VERY easy to get out of hand with doing "while you are in there" stuff. My $.02; make a list, prioritize it, and set your budget. Then stick to it!
And I know there are proponents of both the 1FZ and 3FE on here, but they are both great engines. Putting down one or the other gets our community of LC enthusiasts nowhere and is not productive whatsoever. Good luck to you and keep us updated!
View attachment 1188532 Hi guy's Thought I would give a update.It at a shop I like the mechanic he drives a Toyota and works on them. The head is off and he called to have me come take a look. I'm very happy, The mechanic first words were some one took good care of this. There is no visible wear on the cylinder walls,the head & valves look good in short he said everything looks good he even side all electronical connection we good ( no broken clips) & no stripped hardware like a lot of older regs he works on.
For now, we are sticking to the top end, all new hoses, water pump, thermostat, radiator, shroud, full tune up, wires, cap, etc. All Toyota parts.
Welcome to the club! Just for reference, last weekend I bought a locked 93 with 268k. I went to Oregon to get it bc if the high prices in CA so I think you got a good deal even with the HG job ahead of you.
The guy I bought from had the head gasket done last summer at the Toyota dealer ship for $2100. I know that Toyota recommends a rebuild at 200k but perhaps they underestimated their own product because there are some here on mud with over 400k that have never been apart. I also have a 94 with a rebuilt motor that has only 18k on it and the original engine in my "new" 93 runs smoother, has just as much, if not more, power and does not smoke. So you be the judge of you own engines health.
Do a compression test, does it smoke?, send oil to blackstone labs to find out if there is coolant in the oil. If all this checks good and a full rebuild just isn't possible for you, for what ever reason, then I don't see any reason that you should not be ok just doing the HG. You said it's not a DD so how long will it take to put another 100k on it? And at that point you will still have less miles than many.
But, if your budget allows and you have the facility and ability to do a rebuild, by all means do it because pulling the whole engine is easier than removing just the head while in frame.
Member @Jorgito just finished his and has a great thread documenting the whole process. He called upon us for assistance with lots of questions as he was new car maintenance.
I once considered it until I saw a photo of the insides of an engine that it had been used on and was being legitimately fixed later. Nasty stuff!
I can't believe people actually recommend bar's stop leak. That is the worst advice ever.
Bars makes a lot of different products and Bar's head gasket repair is not the same as stop leak and it doesn't gum up the engine block or cooling system. Just because you aren't familiar with their products and don't know isn't a reason to bad mouth people that know.
There are numerous guys on here that have used Bar's head gasket repair as a "temporary" repair for their head gasket only to still be running on that "temporary" repair. I'll take the first hand experience of those that have used it over the advice of someone that just doesn't believe in it. Really, what do you have to lose by trying it? If it works and buys a person some time, great. If it doesn't, they are out $50.
This seems to be a moot point since the OP already has the head off...
