Birfield conversion?
Diescipel said:
Geez.... why? 90 hp is all I need.
Any probs with stuffin your tires in those wheel wells????....
What exactly are you doing with this thing?
B
old picture of together before build-up. Since then SOA. I now have too much, need to upsize in tires...
stroked 383, 546 ponies, TH350, NP205, chopped 9", 4.56, posi spool .......?
well, lets just say it's all for my Jeep buddies....
It could take most of 550hp to push that bumper around, by it self it should be on a D60.
B
i asked the same thing untill i saw the pics... that rig is a low profile front bumper away from a permanent hard on
Came with the rig.... I would have to agree, this gentleman was artistically challenged! It's been low priority until I got fed up with it a couple of weeks ago. I chopped side wings off, cut all piping except for center square. Looks a hell a lot better now. It'll do until I get time to build my custom. But I have to be honest, the way it used to drive I felt more secure driving with the chunk in the front.
rem_7mmSTW said:
Yes, just what I had in mind.
Thanks Ed!
You might be able to go further backwards with axle tech. by installing older ball and claw axles... and then drum brakes up front......
maybe.
maybe.
I still need a set lol
:D
I never followed through with Jack's offer.
27 posts in this thread, 10 since the pics were posted, and nobody thought it was worthy of comment that the steering box is mounted with bolts AND NUTS!
I always worry when I see things like that.:frown:
maybe.
so with the 30 spline longs, I shouldn't need too worry about distruction "while in reverse and turning wheel to stop limit during high torque" incedents as I've seen and heard so much about?
and...
mounted on high tensil strength machine cut bosses seal welded through 3/8" plate with grade-8 bolts and self locking nuts (believe me, you've got to wrench these all the way)... I actually followed proceedure from a respected conversion shop.
steering boxes are mounted from factory with .....?
You can do whatever you want, but I only run a 2F with 42" Swampers, and I have a 4340 chromo axles, CTM joints, ARB, 4:88's 35 spline in and out front end.
Good luck!
-Steve
Go with longs or newfields. T think your going to break a pinion or u joint before you break one of those. BUt with 550 hp who knows what will grenade under full throttle.
Good luck!
-Steve
thanks poser, you wouldn't happen to have a closer (hub) photo of that under front end?
I need to understand more.
ps. Mean looking rig!
dacicci said:
here is a pic of the one i put on ;)
I think Mike was referring to where you cut the crossmember to fit the steering gearbox. But I could be wrong.;)
Ed
Ed
:doh: ohhh yeah i just welded a gusset on the inside of mine before i put the box in. but i was not to worried about it i have all the horses i needed with the bigggg 2f. nothing gears did not solve. speed kills.
I don't really see your issue, everyone knows screwing into cast sucks, in fact the top hole of my box stripped out, and what did it do? cinched it down with a nut. 2+ years of hard wheeling, still no problems.
bustanutley said:
...everyone knows screwing into cast sucks...
your diff carrier cap bolts are screwed into cast....
your mainbearing cap bolts are screwed into cast....
I am not sure how much it really sux....
:beer:
