I took apart a set of birfs to clean out the questionable grease and re-pack them.
First I tried the PVC pipe method of removing the axle shaft. That didn't work, so I moved on to the FSM technique. I clamped the drive axle in a pipe vise and womped on the center spider with a brass drift and a BFH per the service manual to separate the shaft from the joint. When I was articulating the center spider to remove the balls, it seemed a bit stiff. Removing the balls took a little effort, like they were catching on the cage, but I got them out with some finesse and light taps with a brass drift.
In trying to put is all back together, I can't get the balls back through the cage without them catching and dragging.
I have two sets of birfs, one came on the truck(my '92) and were clicking and worn pretty well in both directions. The other set is off a newer vehicle('96 with a recently "rebuilt" axle). I didn't have any trouble at all getting the original set apart for cleaning, but the new ones are a being a PITA.
Did I ef it up or is this normal? I'm considering using the old cage and balls in the new assemblies, but haven't tried to see if it would work yet.
