Not too well though as usual I am psyched to get it back together. I finally have all the parts to fully put the engine back together (new rebuilt injectors, starter spacer).. I realized this is going to take so long and the $$ especially that I decided to quickly hammer out a mini truck to have something decent to wheel for a couple years until I get this done... We leave in exactly a week for a trip I put together called the Carbon Neutral Expedition (I'm going to try to get the site fully updated shortly)
www.carbonneutralexpedition.com to the Overland Expo...
The truck is:
Thanks guys.. Here are more pics and the buildup thread if anyone is interested.. Specs are:
-1990 Toyota Extra Cab
-Mercedes OM617 diesel, tweaked and juiced, custom 3" exhaust, Saab 9000 115 amp alternator that bolts in, easier than wiring a GM alternator (same principle, uses idiot light ground). Big FZJ80 air cleaner. Single Die Hard 930cca Platinum battery.
-custom motor mounts using 4BT solid rubber motor mounts (only $8 each, very similar to mini truck motor mounts but beefier - mounted 45 degrees).
4x4 Labs adapter to GM pattern (work of art)
-Marlin 23 spline trans (using AA bellhousing to GM)
-Centerforce 21 spline clutch disk, LUK (Napa) clutch
-2.28 doubler
-4.7 t case
-custom cross member
heavy duty SFA with the coils/suspension seen here.
- Marlin rear bumper and sliders
- ARB bumper with M12000 I have lying around, ARB trimmed out to fit the M12000.
- Pretty badass custom galvinized or powdercoated headache rack with spare tire mount.
- Old Man Emu heavy suspension rear.
- Taco V6 diff.
- 33" Treadwright MTR pattern retreads on a 17" FJ Cruiser wheel
- clean body, painted white.
- at some point veggie oil kit with a 20 gallon aluminum tank out of a
Summit Racing non foam fuel cell.
- 15 gallon H20/methanol kit to I can tow pretty well with it also and have balsy good highway power as needed.
(only components I need for this are some of the veggie oil components and the two tanks, already have the adjustable H20/methanol kit that reacts to boost pressure).
In general heavy as hell, designed for desert hauling ass, light air, and long miles as comfortable as possible and hopefully 25 mpg...
[/URL]
Expedition Portal thread which is slightly more weak sauce...
4BT swaps build thread (shows the engine bay fab work, cross member work, radiator etc as the 5 cyl diesel is long)
Before & after...
