Build Big Red Toy
I was thinking the same Johnny, IIRC its the 80 Front that is different.. I'll have to get learned up a little more on it. I have FF front and rear on my 60. But, sounds like he wants new parts and well... I want BIGGER TIRES.. Kinda worked itself out HA! The 345 75 16 KM2s are back in stock..
J
I think the 80 front won't work because of the high pinion, but don't quote me on it. Jason, I'm down for switching diffs if it will work. I just did't want the rig down too long. I'll PM you later about it. I need to get some work done.
M
Oh s***, you have a FF in the rear too? Then there's nothing to worry about, it's all plug and play. I had a FZJ80 e-locker in my FJ60 FF rear axle for a couple of years, and it worked great! The non-elocker diffs will work without modification in the FJ60 FF rear.
Right on... Good to know, thanks again Johnny. Is the flange the same as well??
J
M
PM me, I could send the 3.73s whenever, they came out of my '85 and have 189,452 miles on them (I wrote the odometer reading on the shipping containers when I pulled them) so you may want to weigh that as well...
J
They should be fine, mine have about 210000 on them. I'll just put the front diff in the rear. I'll finish up some stuff and figure out how to pm you.
Did this over lunch real fast.
I had a 3/8 all thread rod in the garage that I used to make sway bar linkages to replace the ones that broke. Odds are 3/8 stainless steel might break as well. If they do I'm going half inch.
I wire brushed the surface rust and repainted the sway bar.
The I took measurements and sawed the rod
this is it mounted
cut off the excess at the bottom
and finally replaced the last fuel line. I'm still waiting on brackets that bolt to the engine and hold the lines in place, should arrive tomorrow.
It should be noted that line number 2 gave me the hardest time. It was just out of alignment and wouldn't bend. the others fit perfectly.
Time for some advice. You guys who are following already know I want to regear to 3.73 and it looks like I will be trading my 4.1s with Reevesci. Now the opportunity came up to buy an Auburn limited slip locker for $200. Would anyone put that in with my kind of set up? Or should i save up for a detroit for the rear. I know the detroits are locked all the time with the occasional release. has anyone used the either the auburns o detroits and what would you recommend? Thanks for all your input.
An auburn limited slip is a clutch style and those can wear out, especially with your bigger and heavier tires. An auburn vs a Detroit isn't really a fair comparison with the Detroit being stronger but it also being a locker and not a limited slip. For me and the wheeling I like to do a locker is a better choice.
Boots, thanks for your honest reply. I realised I wasnt comparing apples to apples, but I've heard so many bad reviews about the Detroits on road driving. Ideally I'd like a mechanically actuated locker, something I can pull a switch or lever and select. I think I'm going to pass on the auburn and just focus on the regearing for now. I've neglected so many other hobbies by just focusing on my truck.
Got my fuel brackets in. Had to modify one to fit, nothing sexy just peace of mind. I also got a notice from a corbeau distributor that they will be shipping my seat brackets soon.
Just save up for an ARB or 80 series e-locked third member. Daily driving a lunch box locker would drive you nuts.
you named your new rig Walter White, that's hilarious.
I need a Heisenberg sticker!
http://data:image/jpeg;base64,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
I could not agree more. I tried the lunch box locker and hated it. Guys with automatics don't seem to mind as much, or maybe I'm picky, but save up for the selectable locker either way.
I just got this sticker for mine. will save for the selectable lockers, probably means next year or the next. So far I haven't needed lockers.
Nothing really worth mentioning. Took out old stickers, put on new ones. Tomorrow I'm replacing front U bolts and adding some shims. Thursday I should get my seat brackets.
I can see better out the rear now
