Build Big Green Buffalo Build Thread
Looks good !
How many inches to the bottom of the sliders ?
Got the drivers slider fully done. Ill have to get some pictures of the inside, what a bitch to weld.. The fender has been re-trimmed, much more round to match the rear and cut off to accommodate the slider. I made a mount and drilled some holes to secure the lower part of the fender.
f*** it, ill just shave the sunroof.. thanks a lot hahaha
Haha. You could drill a drain hole on the bottom each end of the slider. Also, if you look on the floorboard just outside of the A-pillar kick panels there is a grommet you can re-route the drain tubes to. I haven’t done it, but I know they reach.
Do you plan to lower the rig, now that you increased your clearances & uptravel?
Im mocking up the right side slider, the left side is done already..
How are the sliders attached to the body or frame, I know you welded but I am interested in having our fabricator do something similar for me.
Its just a 2x6x3/16 welded to the body, rocker cut off and replaced with big steel. The 2x6 is attached to the A,B,C pillars each with a piece of 3/16 plate, to beef up the structure a bit. I have no fantasy that this is stronger or better than a frame mounted slider. This does add some ground clearance and a long smooth flat surface to actually slide across rocks, with no mounting brackets to get hung up on the very same rocks, nothing attached to the frame.. but pros and cons ya know.. THE single biggest reason i did this though, i watched my german shepherd get out of the truck and put his leg right through the hole of my white knuckle slider, the future of him breaking his leg like that flashed before my eyes and i knew right then….
Pictures? I was in the Navy and we used pup up books... LOL!!!
