I decided to cut the spot welds and remove this piece from the bottom of the bib, since it looked pretty suspect.
Sure enough, major rust flakes.
It's pretty close to rusting through the outer panel.
All due respect to the engineers who designed this, butw what a terrible design.
Shouldn't be too bad to fix and put back to original, but I'm hesitant to do that since it's just going to rust out again. This spot welded support piece will just trap moisture. Granted, it has lasted since 9/75, so I'll be dead by the time it needs replacing again.
The bib hinge bolts through this area, but it doesn't seem like the support is a necessary part. What do you think about just replacing the outer skin and throwing the support piece out?
The only thing I can think of is that the support is needed to prevent bending and twisting when you unbolt the bib from the fenders and use the hinge to fold it forward... Which is something I never do.
I'm doing a frame off, but this is a restomod. It had a small block Chevy and a ranger overdrive in it when I bought it. So originality isn't as important to me. I just want it to last a long time!
Thanks
Peter
Thanks
Peter
poor design/ last since 9/75/engine changed to V8.
