Yes, It does fit without the need to deflate.Do we know if the 285/75r17 will fit in the stock spare tire location w/o airing down?
Is there enough extra space that a marginally taller tire would still fit? Asking because BFGs are notoriously undersized relative to the same size from another manufacturer. I am running Toyo AT2 and am hoping to squeeze my spare up there still. I'd check for myself, but I don't have a spare in that size yet.Yes, It does fit without the need to deflate.
*EDIT* I see in this thread that @TexAZ mentioeds that a 295/70r18 fits in the stock location with little a modification, so that should mean I'm clear.
...This is a 295/70/18 Cooper AT3 XLT in my spare locationIs there enough extra space that a marginally taller tire would still fit? Asking because BFGs are notoriously undersized relative to the same size from another manufacturer. I am running Toyo AT2 and am hoping to squeeze my spare up there still. I'd check for myself, but I don't have a spare in that size yet.
*EDIT* I see in this thread that @TexAZ mentioned that a 295/70r18 fits in the stock location with little a modification, so that should mean I'm clear.
No margin for error there! Thank you, that helps a lot.This is a 295/70/18 Cooper AT3 XLT in my spare location
Anyone know what the actual tread width of 285/75/17 Ridge grappler is? The same size in KO2 is 9.4” at 4.5lbs per tire less. Not bad
flattread touching street, barely 9 to 9 1/2
Sidewall to fat sidewall mounted puffs out to 11 1/2
Aired down contact .. Huge.
I have the Nitto RG 285/75R17 and the rubbing on my drivers KDSS arm is so slight you’d never hear it or notice unless you climb under the truck. I do rub the passengers side sway bar at left full lock. I run Icon +25 offset wheels though and have SPC UCAs
Have you measured the actual height of your RG?I have the Nitto RG 285/75R17 and the rubbing on my drivers KDSS arm is so slight you’d never hear it or notice unless you climb under the truck. I do rub the passengers side sway bar at left full lock. I run Icon +25 offset wheels though and have SPC UCAs
285/75r17 KO2 on Rock Warriors compared to 285/75r17 Ridge Grapplers on Evos. Both with 5,000 miles on them under a 200. Both inflated to 37 psi (per @gaijin... never question gaijin!)
Both are 32.63" tall when mounted on the recommended 8" rim, under the the same 200's weight according to one of Bud's lasers. When mounted on the rim, inflated to max pressure, but not under the weight of a truck, they do hit the 33.9" advertised height (where that number comes from).
Below is the KO2.
Below is the Ridge Grappler
KO2s with Rock Warriors: 86 pounds
Ridge Grapplers with Evos: 94 pounds (Evos are lighter than any of the Methods, Icons, or really whatever else is popular I've seen come through the shop)
I doubt you will be replacing wheel bearing or steering links sooner than 120k regardless of any of those wheel/tire selections. The size of a 200 series components are considerably larger than that of the GX/4Runner/Tacoma parts and those handle larger tires and more non sense drivers than you will subject your 200 to. In the end, you’ll have a wheel bearing (most likely) fail due to a seal failure and let dirt in before you’ll damage it from unsprung weight.Thanks for the photos and information comparison. Keep in mind the Nitto does weigh about 5lbs more as well. 17” ICON rebound weighs 27lbs and combined with a KO2 in 285-75/17 is total 88lbs or 93lbs with the RG.
I believe my 18” method Con6 +18 wheel weighs around 37lbs and surprisingly my 35x12.50r18KO2 only weighs 64lbs.,making my current setup 101lbs per wheel.(heavy) no wonder the 200 struggles a little.
Do you believe it’s worth it for me to drop down to a 17” ICON and 285/75/17 RG to save roughly 8lbs per tire? If I went with a Cooper AT3 XLT it would shave off another 6lbs per tire or should i just drop my current tires down to a 295/70/18 and not switch out my wheels.
My goal is to reduce wear and tear on wheel bearings, etc. If shaving 8lbs per tire isn’t going to make much difference and not worth the cost, i could just drop to the 295/70/18 Cooper XLT as it weighs 59lbs which reduces my tire weight by 5lbs vs current setup
isn't it 285mm?Anyone know what the actual tread width of 285/75/17 Ridge grappler is? The same size in KO2 is 9.4” at 4.5lbs per tire less. Not bad
isn't it 285mm?
Alright, I must be in a similar boat to most that have tried this setup. I have the basic 2.0" OME NitroCharger front lift with SPC upper control arms, 0.75" rear lift. Rock warrior wheels and installed 285/75-17 BFG KO2's. I had alignment done the same day as the lift. It's well in spec and drives beautifully. From reading many hours worth of posts here I expected the mud flap rubbing issue and the need to push the fender liner forward. I also have the slightest rub on the KDSS bar on the drivers side. You can't hear it or feel it but missing dirt is evidence. Those issues did not surprise me. I must have somehow missed rubbing issues on the passenger side sway bar. It's serious enough you can feel it and hear it at full lock. Am I missing something? Did I do something wrong? I expect wheel spacers would fix the rubbing issue on the sway bar but am I asking for more trouble?
I understand that going down one size to 285/70-17 that Toyota approved is the easy answer and that's not completely out of the question. From wheeling in SW Colorado my whole life and finally joining the LC family I've always wanted to fit these specific tires so that am willing to do some more work. I am not set on this at all costs. The rig must be as dependable as possible and I will not accept permanent rubbing issues.
Hoping I don't get flamed too much for a topic that has been discussed here a lot. View attachment 2399251View attachment 2399255View attachment 2399257
I think you should be able to fix this as some others run your same setup and don't have the issue.Alright, I must be in a similar boat to most that have tried this setup. I have the basic 2.0" OME NitroCharger front lift with SPC upper control arms, 0.75" rear lift. Rock warrior wheels and installed 285/75-17 BFG KO2's. I had alignment done the same day as the lift. It's well in spec and drives beautifully. From reading many hours worth of posts here I expected the mud flap rubbing issue and the need to push the fender liner forward. I also have the slightest rub on the KDSS bar on the drivers side. You can't hear it or feel it but missing dirt is evidence. Those issues did not surprise me. I must have somehow missed rubbing issues on the passenger side sway bar. It's serious enough you can feel it and hear it at full lock. Am I missing something? Did I do something wrong? I expect wheel spacers would fix the rubbing issue on the sway bar but am I asking for more trouble?
Hoping I don't get flamed too much for a topic that has been discussed here a lot. /QUOTE]
I run a stock 2013 LC200 with the 17" TRD wheels and LT285/70R17 tires as recommended by Toyota. I am confident - and have experienced so far - that there is no road or trail condition I can put myself into that will result in any rubbing. In fact, the truck feels like it was built for this tire/wheel combination.
