I think Dusty's comment about the 2lb D ring speaks to my concerns. The factory recovery points are stout. They'll handle hanging the 80 by a single one from a crane. The crane could let it freefall a foot and it still wouldn't let go. They're that strong.
By way of comparison, my big tow strap (you know, the one you keep in your kit that you won't get out for any stuck - you use the other one for that) is rated to 27,000lbs. That's 4 and a half 80s hanging. Frames are rated at the amount of force required to flex them an inch IIRC (this is from my product planning days, so forgive my inexactness). The last model of Isuzu Trooper had a frame rated at around 65,000lbs of force. Now these are figures I just want to throw out so you know the kind of forces it takes to bend frames - I don't know what the 80s corresponding figure is.
But I do know that it would be proper engineering procedure to design an attachment point on a frame intended to be used for recovery in such a way that it's strength is matched to the frame. To design it to pull off easily would be a huge liability issue. In other words, having the hook pull off before deforming the frame would be unacceptable. It should remain attached to the frame while deforming it - this is not an application where an engineer would design it to fail as a "fuse" to prevent frame damage. No way. That Toyota chose to make it a closed loop that is much stronger than an open hook should also say something. The hook is more user friendly, but they passed on that design to get strength.
I don't know the circumstances of the one single failure that has been reported and when I read the thread I did not get any information at all. Was it a side pull? Had the loop been damaged by previous recoveries? Had it been damaged by repeated rock contact (I've seen these mashed sideways)? Had it been removed and replaced perhaps not at the correct torque which allowed the base to roll and crack the weld? Dunno. If someone had definitive knowledge of this stuff it would be good to know. Not someone who was just there and saw it fail, but the actual truck owner who could say "I bought the truck new and nobody had ever removed that hook and it had been scraped as usual from wheeling but not seriously distorted." THAT would bother me, frankly.
So, just a stream of consciousness ramble to give you some numbers and thoughts on how strong these things are. All bets are off if someone's removed them to put on a trailer hitch or a front bumper and replaced the factory fasteners with longer ones to fit over something, etc.
I guess what I'm trying to convey is that I would not be worried about the factory attachments if they're unmolested. If I personally buried my 80 to the headlights in mud and the next day hired a D9 to pull it out I'd rig a bridle to use both front hooks and try to get the pull as straight ahead as possible. The bridle would not have a short piece from each hook that creates a side load, it would be as long as practical so both are getting a straight pull. I'd also ask the operator not to slam the recovery chain. Just normal respect of the dangers. And I personally would not be worried about pulling off the hooks.
If it had to be a side pull, I'd be very concerned and be looking for a way to share the load elsewhere because now you're pulling tires sideways rather than forward and loads might double easily. Now I'd move to pulling tires and attaching straps to the frame through the wheel opening, etc. At this level and direction, ANY attaching point would be suspect. I don't care who's front bumper is on there and how well it's attached. I'd go directly to the frame with webbing and padding.
So keep things in perspective. If this type of stuck is part of your scenario then the factory points are not adequate, but you still have options that involve direct attachment to the vehicle's hard points (frame).
Whatever you do, keep the 2lb D-ring on your mind. Every single year experienced wheelers get killed in this fashion. Sadly, it's usually the experienced wheeler being a good samaritan getting killed because the attachment failed on the stuck rig, not his own well prepared vehicle. Don't be that guy....
Best to simply drive an 80 and don't get stuck
DougM
