So... after owning my '77 FJ45 for 4 days (my first car by the way!) I got into an accident and haven't been able to drive it for months
I was hit in the front driver's side wheel and when I took the steering knuckles apart I wasn't able to pull the left hand drive shaft out of the axle housing.
That's when I realised the knuckle housing is crimped over the birfield joint and doesn't give the driveshaft enough room to be pulled out.
Can it be bent back or should I just get a new housing?
Since everything is already apart, is there anything else I should take the opportunity to do? I already have a knuckle rebuild kit with new wheel bearings. I was planning on switching to disk brakes at some point, does it make sense to do that now?
Thanks, and sorry if this question is already answered somewhere, I tried searching and couldn't find anything specifically addressing this problem.
And I'm not sure what makes the most sense between either axle. Logically, it seems like it would probably be easier to put the disk brake axle in... but I think I've also read that it's nice to have the conversion kit because it makes getting replacement rotors and pads easier (and cheaper).
