I'd be taking a hard look at the harmonic balancer first, anybody that would use a pry bar instead of a socket would also use a strap wrench on the balancer pulley to try and keep the motor from turning and possibly damaged the rubber mounting. The fix may be as simple as a new balancer. If the starter doesn't grind, drag, or pulse abnormally then I'd look elsewhere. Or, you could pop off the inspection cover, get a flashlight, and check the flywheel for yourself. Take about two minutes and sombody else to turn the motor by hand. A smart guy with a smart phone could probably figure out a way to do it all by himself, but all that smart tech is beyond me.
I always check things myself- been told too many wrong things, both intentionally and unintentionally, along the way to not make sure myself. Especially before spending money!
Hope this helps.
EDIT- whups, missed that you saw the bent hole in the flywheel, I guess the question then is how bad is it really? How far out is it, and does it matter all that much? Can you bend it back close enough to straight to get a few more years out of it or is it really shot? And is that the only problem? If the rest of the truck is good I'd say run it as is and watch for a good used motor to come along or just save up the pennies for a good rebuild job. 250k on a rust free truck is peanuts, it's barely broken in at that point. Just my two cents.
